Checks
This topic describes how to create baseline check plans. To use cloud service baseline inspection, you need to create check plans first.
- Click in the upper part of the page and choose Security > SecMaster.
- In the navigation pane on the left, choose Workspaces > Management. In the workspace list, click the name of the target workspace.
Figure 1 Workspace management page
- In the navigation pane on the left, choose Settings > Checks.
Figure 2 Checks page
- On the Checks page, click Create Plan. The pane for creating a check plan is displayed on the right.
- Configure the check plan.
- Enter the basic information by referring to Table 1.
- Select a security standard for the plan.
- Click OK.
After the check plan is created, SecMaster performs cloud service baseline scanning at the specified time. You can choose
to view the scanning result.
