Updated on 2024-07-18 GMT+08:00
Configuring and Enabling a Playbook
By default, SecMaster provides playbooks such as Fetching indicator from alert, Synchronization of HSS alert status, and Automatic closing of repeated alerts. The initial version (V1) of the playbooks has been activated. You only need to enable them.
If you need to edit a playbook, you can copy the initial version and edit it.
This section describes how to configure and enable a playbook.
Enabling a Playbook of the Initial Version
  2. Click in the upper part of the page and choose Security > SecMaster.
  3. In the navigation pane on the left, choose Workspaces > Management. In the workspace list, click the name of the target workspace.
    Figure 1 Workspace management page
  4. In the left navigation pane, choose Security Orchestration > Playbooks.
    Figure 2 Accessing the Playbooks tab
  5. In the Operation column of the target playbook, click Enable.
  6. Select the playbook version to be enabled and click OK.
Enabling a Playbook of a Custom Version
Accessing the Playbook Version Management Page
    Figure 3 Workspace management page
    Figure 4 Accessing the Playbooks tab
Copying a Playbook Version
  1. In the Operation column of the target playbook, click Versions.
  2. On the Version Management slide-out panel, in the Version Information area, locate the row containing the desired playbook version, and click Clone in the Operation column.
  3. In the displayed dialog box, click OK.
Editing and Submitting a Playbook Version
  1. On the Version Management slide-out panel, in the Version Information area, locate the row containing the desired playbook version, and click Edit in the Operation column.
  2. On the page for editing a playbook version, edit the version information.
  3. Click OK.
Reviewing a Playbook Version
  1. After the playbook version is edited and submitted, the playbook management page is displayed. On the Playbooks page, click Version Management in the Operation column of the target playbook.
  2. On the Version Management slide-out panel, click Review in the Operation column of the target playbook.
  3. In the displayed dialog box, set Comment to Passed and click OK.
Enabling a Playbook
  1. On the Version Management slide-out panel, click Enable in the Operation column of the target playbook.
  2. In the slide-out panel, select the playbook version you want to enable and click OK.
