Updated on 2024-07-18 GMT+08:00
Managing Parsers
This topic describes how to perform the following operations: Viewing Parsers, Importing a Parser, and Deleting a Parser.
Viewing Parsers
  2. Click in the upper part of the page and choose Security > SecMaster.
  3. In the navigation pane on the left, choose Workspaces > Management. In the workspace list, click the name of the target workspace.
    Figure 1 Workspace management page
  4. In the navigation pane on the left, choose Settings > Collection Management. On the displayed page, click the Parsers tab.
    Figure 2 Accessing the Parsers tab page
  5. On the Parsers page, view the detailed information about parsers.
    Table 1 Parsers parameters
    Name
    Name of the parser.
    Channel
    Number of channels that are used by the parser
    Description of the parser.
    Operation
    Operations such as editing or deleting the parser
  6. On the Parsers page, click the Templates tab.
  7. On the Templates tab displayed, view the parser templates you can use.
    Table 2 Parser template parameters
    Name
    Name of a parser template
    Description of the parser template
    Operation
    Creating a parser from a template.
Importing a Parser
  • Only .json files no larger than 1 MB can be imported.
  • A maximum of five parser files can be imported at a time, and each parser file can contain a maximum of 100 parsers.
    Figure 3 Workspace management page
    Figure 4 Accessing the Parsers tab page
  5. On the Parsers tab, click Import in the upper left corner above the parser list.
  6. In the displayed Import dialog box, click Select File and select the JSON file you want to import.
  7. Click OK.
    You can view imported parsers in the parser list.
Exporting a Parser
    Figure 5 Workspace management page
    Figure 6 Accessing the Parsers tab page
  5. On the Parsers page, select the parsers you want to export and click Export above the list.
    The system automatically downloads the parser file in .json format to your local PC.
Deleting a Parser
    Figure 7 Workspace management page
    Figure 8 Accessing the Parsers tab page
  5. On the Parsers tab, locate the row that contains the target parser and click Delete in the Operation column.
  6. In the displayed dialog box, click OK.
