Pie Charts
The query and analysis results can be displayed in a pie chart.
The pie chart is used to show the proportion of different categories. Different categories are compared by radian.
- Click in the upper part of the page and choose Security > SecMaster.
- In the navigation pane on the left, choose Workspaces > Management. In the workspace list, click the name of the target workspace.
Figure 1 Workspace management page
. The security analysis page is displayed.Figure 2 Accessing the Security Analysis tab page
- In the data space navigation tree on the left, click a data space name to show the pipeline list. Click a pipeline name. On the displayed page, you can search the pipeline data.
Figure 3 Pipeline data page
- Enter the query and analysis statement, set the time range, and click Query/Analyze.
- Click the Charts tab. In the Chart Type area on the right of the page, click .
Figure 4 Pie chart statistics
- Set pie chart parameters.
Table 1 Pie chart parameters Category
Base Settings
Title
Customized line chart title
Chart Settings
Classify
Data classification
Column Value
Value of the data type
Legend
Show Legend
Determine whether to display the legend.
Position
This parameter is mandatory when the legend display function is enabled.
Position of the legend in the chart. The options are Top, Bottom, Left, and Right.
After the chart is configured, you can preview the configured data analysis result on the left.
Related Operations
- Adding an indicator card: After the configuration, if you want to save the indicator information as a card, click Add as Indicator Card in the upper right corner of the table to add an indicator card. In the dialog box that is displayed, set the indicator card name and click Save.
- Download logs: After the chart configuration, you can click Download in the upper right corner of the table to download the current query analysis data to the local PC.
- Hide configuration: After the chart configuration, you can click Hide Configuration on the right of the Preview to hide the parameters.
- Show configuration: After the chart configuration is hidden, you can click Show Configuration on the right of Preview to expand and set parameters.
