Updated on 2024-07-18 GMT+08:00
Creating a Pipeline
A data transfer message topic and a storage index form a pipeline.
To use the security analysis, data analysis, and intelligent modeling functions provided by SecMaster, you need to create pipelines.
This section describes how to create a pipeline.
  2. Click in the upper part of the page and choose Security > SecMaster.
  3. In the navigation pane on the left, choose Workspaces > Management. In the workspace list, click the name of the target workspace.
    Figure 1 Workspace management page
  4. In the navigation pane on the left, choose Threat Operations > Security Analysis. The security analysis page is displayed.
    Figure 2 Accessing the Security Analysis tab page
  5. In the data space navigation pane on the left, click on the right of the data space name and select Create Pipeline from the drop-down list box. The Create Pipeline page is displayed on the right.
    Figure 3 Creating a pipeline
  6. On the Create Pipeline page, configure pipeline parameters. For details about the parameters, see Table 1.
    Table 1 Creating a pipeline
    Data Spaces
    Data space to which the pipeline belongs, which is generated by the system by default.
    Pipeline Name
    Name of the pipeline. It must meet the following requirements:
    • The name contains 5 to 63 characters.
    • The value can contain letters, numbers, and hyphens (-). The hyphen (-) cannot be used at the beginning or end, or used consecutively.
    • The name must be unique in the data space.
    Shards
    The number of shards of the pipeline. The value range is 1 to 64.
    An index can potentially store a large amount of data that exceeds the hardware limits of a single node. To solve this problem, Elasticsearch subdivides your index into multiple pieces called shards. When creating an index, you can specify the number of shards as required. Each shard is in itself a fully-functional and independent "index" that can be hosted on any node in the cluster.
    Lifecycle
    Life cycle of data in the pipeline. Value range: 7-180
    Remarks on the pipeline. This parameter is optional.
  7. Click OK.
    After the pipeline is created, you can click the data space name or next to the data space to view the created pipeline.
