On this page
Viewing Products
Updated on 2022-12-05 GMT+08:00
Overview
After a product is created, you can view and reset the product certificate, and import and export the product.
Functions
After a product is created, you can view and edit the product as required by referring to the following table.
Table 1 Function description
Function
Viewing a product certificate
A product certificate can be used as a credential for accessing the device to which a product belongs. All devices under a product can use one product certificate for authentication.
Click in the Password column to view the product certificate.
Importing products
If a file already exists on the local host, you can click Import on the Products tab page to import the file that contains product information.
To obtain a file template, create a product on the console, select the product, and click Export to export a CSV file. Then, you can modify the CSV file based on the product to be imported.
The imported product information does not contain attributes and commands of the thing model and thing model service. You can manually create them after the import.
Exporting specified or all products
Export information about one or more products to a CSV file.
To export one or more products, select the products to be exported and click Export. To export all products, click Export All.
The exported product information does not contain the thing model and the attributes and commands of the thing model service.
Resetting a password
To change the password (product certificate), click Reset Password in the Operation column of the target product.
Editing a product
Click Edit in the Operation column of the target product. Product Type, Protocol Type, and Application cannot be modified.
Deleting one or more products
Delete a created product.
To delete one or more products, select the required products and click Delete. You can also click Delete in the Operation column of a specific product to delete it.
