On this page
Connecting to an FI Kafka Data Source
Updated on 2023-07-26 GMT+08:00
Overview
ROMA Connect can use Kafka as a data source for data integration tasks. Before using the FI Kafka data source, you need to connect it to ROMA Connect.
Each connected data source must belong to an integration application. Before connecting a data source, ensure that an integration application is available. Otherwise, create an integration application first.
  1. Log in to the ROMA Connect console. On the Instances page, click View Console next to a specific instance.
  2. In the navigation pane on the left, choose Data Sources. In the upper right corner of the page, click Access Data Source.
  3. On the Default tab page, select FI Kafka and click Next.
  4. Configure the data source connection information.
    Table 1 Data source connection information
    Name
    Enter a data source name. It is recommended that you enter a name based on naming rules to facilitate search.
    Integration Application
    Select the integration application to which the data source belongs.
    Enter the descriptive information.
    Machine-machine Username
    Enter the Kerberos authentication username for accessing the Kafka server, for example, ioc.
    Configuration File
    Click Upload File to upload the FI Kafka configuration file. For details, see Obtaining the FI Kafka Configuration File.
    1. Obtain krb5.conf and user.keytab files.
      Download the user authentication file from MRS Manager by following the procedure described in "Downloading a User Authentication File" in the MapReduce Service User Guide, and decompress the file to obtain the krb5.conf and user.keytab files.
    2. Obtain the fikafka-producer.properties, fikafka-consumer.properties, and hosts files.
      Download the client configuration file from the MRS console by following the procedure described in Downloading a Client Configuration File > Using Hive from Scratch in the MapReduce Service User Guide. After the file is decompressed:
      Obtain the fikafka-producer.properties and fikafka-consumer.properties files from xxx_Services_ClientConfig_ConfigFiles > Kafka > config.
      Copy the value of bootstrap.servers in the fikafka-producer.properties file to the fikafka-consumer.properties file.
    3. Generate the FI Kafka configuration file.
      Save the obtained files to a new directory and compress them into a .zip package. All files are stored in the root directory of the .zip package.
      • The file name contains a maximum of 255 characters, including only letters and digits.
      • The file size cannot exceed 2 MB.
  5. Click Check Connectivity to check the connectivity between ROMA Connect and the data source.
    • If the test result is Data source connected successfully, go to the next step.
    • If the test result is Failed to connect to the data source, check the data source status and connection parameters, and click Recheck until the connection is successful.
  6. Click Create.
