On this page
Connecting to an FTP Data Source
Updated on 2023-07-26 GMT+08:00
Overview
ROMA Connect can use FTP as a data source for data integration tasks. Before using the FTP data source, you need to connect it to ROMA Connect.
Each connected data source must belong to an integration application. Before connecting a data source, ensure that an integration application is available. Otherwise, create an integration application first.
  1. Log in to the ROMA Connect console. On the Instances page, click View Console next to a specific instance.
  2. In the navigation pane on the left, choose Data Sources. In the upper right corner of the page, click Access Data Source.
  3. On the Default tab page, select FTP and click Next.
  4. Configure the data source connection information.
    Table 1 Data source connection information
    Name
    Enter a data source name. It is recommended that you enter a name based on naming rules to facilitate search.
    Integration Application
    Select the integration application to which the data source belongs.
    Enter the descriptive information.
    Protocol
    Select the protocol for connecting to the FTP data source. The options are FTP and SFTP.
    Connection Address
    Enter the IP address and port number for connecting the FTP data source.
    Username
    Enter the username used for logging in to the FTP data source.
    Password
    Enter the password used for logging in to the FTP data source.
    Connection Mode
    This parameter is mandatory only if Protocol is set to FTP.
    Select the connection mode of the FTP data source.
    • Active: The FTP server actively connects to the data port on the FTP client.
    • Passive: The FTP server waits for the FTP client to connect to its data port.
  5. Click Check Connectivity to check the connectivity between ROMA Connect and the data source.
    • If the test result is Data source connected successfully, go to the next step.
    • If the test result is Failed to connect to the data source, check the data source status and connection parameters, and click Recheck until the connection is successful.
  6. Click Create.
