On this page
Connecting to a DIS Data Source
Updated on 2022-12-05 GMT+08:00
Overview
ROMA Connect can use the DIS database as a data source for data integration tasks. Before using the DIS data source, you need to connect it to ROMA Connect.
Each connected data source must belong to an integration application. Before connecting a data source, ensure that an integration application is available. Otherwise, create an integration application in advance.
  1. Log in to the ROMA Connect console. On the Instances page, click View Console next to a specific instance.
  2. In the navigation pane on the left, choose Data Sources. In the upper right corner of the page, click Access Data Source.
  3. On the Default tab page, select DIS and click Next.
  4. Configure the data source connection information.
    Table 1 Data source connection information
    Name
    Enter a data source name. It is recommended that you enter a name based on naming rules to facilitate search.
    Integration Application
    Select the integration application to which the data source belongs.
    Enter the descriptive information.
    Stream Name
    Enter the name of the DIS stream to be connected.
    Data Type
    Select the source data type of the DIS stream. Currently, only JSON is supported.
    Configuration Type
    Select the configuration type of the DIS stream.
    • Basic: The DIS stream created by the current user in the current region can be called by default.
    • Advanced: DIS streams of different users in different regions can be called.
    AK
    Enter the AK of the user to which the DIS stream belongs. The AK and SK are long-term identity credentials of the user on the cloud service platform.
    SK
    Enter the SK of the user to which the DIS stream belongs. The AK and SK are long-term identity credentials of the user on the cloud service platform.
    Endpoint
    This parameter is mandatory only if Configuration Type is set to Advanced.
    Enter the endpoint of the DIS stream in the format such as https://dis.region1.example.com.
    Region
    Enter the region where the DIS stream is located.
    Project ID
    Enter the ID of the project to which the DIS stream belongs.
    The following is an example of connecting to a DIS in other regions.
    Figure 1 DIS data source configuration example
  5. Click Check Connectivity to check the connectivity between ROMA Connect and the data source.
    • If the test result is Data source connected successfully, go to the next step.
    • If the test result is Failed to connect to the data source, check the data source status and connection parameters, and click Recheck until the connection is successful.
  6. Click Create.
