Configuring Source Information
Overview
This topic describes how to configure source information for a data integration task. Based on the source information, ROMA Connect integrates data, including the data source type, data format, and data range. The source information configuration varies depending on data source types.
Data Source Types Supported by Scheduled Integration Tasks |
Data Source Types Supported by Real-Time Integration Tasks |
API
If Integration Mode is set to Scheduled, you can select API as the data source type at the source.
- On the Create Task page, configure source information.
Table 1 API information at the source Parameter
Instance
Select the ROMA Connect instance that is being used.
Integration Application
Select the integration application to which the API data source belongs. Ensure that the integration application has been configured in Connecting to Data Sources.
Data Source Type
Select API.
Data Source Name
Select the API data source that you configured in Connecting to Data Sources.
Paging
This parameter specifies whether data is returned on multiple pages when ROMA Connect sends a request to the API data source to obtain data. Multiple data records can be returned for one API request.
- If Paging is enabled, all data that meets the conditions is displayed on multiple pages based on the fixed number of records on each page. Each time an integration task is executed, ROMA Connect sends multiple API requests to obtain all data. That is, each API request is sent to obtain data on one page.
- If Paging is disabled, ROMA Connect obtains all data that meets the conditions through one API request.
Page Number Field
This parameter is mandatory only if Paging is enabled.
Enter a page number field defined in the API data source, for example, pageNo. This parameter is carried when ROMA Connect sends an API request to the source to specify the number of the page from which data is to be obtained. Value indicates whether the page number starts from 0 or 1. Set Value based on the original definition of the API.
The page number field must be configured in Params or Body of Request Parameters.
Page Size Field
Enter a page size field defined in the API data source, for example, pageSize. This parameter is carried when ROMA Connect sends an API request to the source to specify the maximum number of records on each page. Set the number of records on each page based on the original definition of the API.
Maximum Number of Pages
This parameter specifies the maximum number of pages that can be queried in each scheduled task, for example, 10. If the number of pages exceeds the specified value, the task is stopped. The value 0 indicates that no restriction applies.
Pagination End
Select the method to stop obtaining source data in pagination mode.
- Empty page list: If no data record is returned, ROMA Connect stops obtaining source data.
- Number of records: ROMA Connect compares the calculation result between the number of requested pages and the page size with the total number of records to determine whether to stop obtaining source data.
Pagination End Field Path
Enter the path of the field in an API response, which is used to determine the end of pagination. In the API response, elements in different layers are separated by periods (.). For example, if element c in the {"a":{"b":{"c":"xxx"}}} response is the pagination end field, the pagination end field path is set to a.b.c.
- If Pagination End is set to Empty page list, set this parameter to the root path of the list field.
- If Pagination End is set to Number of records, set this parameter to the path of the total number of records.
Incremental Migration
This parameter specifies whether only data generated in a specific period is integrated.
For the first scheduling, the data between the initial timestamp and the current scheduling time is collected. For subsequent scheduling, the data between the last successful collection time and the current time is collected.
Start Time Field
This parameter is mandatory only if Incremental Migration is enabled.
Enter the start time field originally defined in the API data source, for example, startTime. This parameter is carried when ROMA Connect sends an API request to the source, indicating that data following the specified field will be obtained.
The start time field and end time field must be both entered in Params or Body of the Request Parameters.
End Time Field
Enter the end time field originally defined in the API data source, for example, endTime. This parameter is carried when ROMA Connect sends an API request to the source, indicating that data before the specified value will be obtained.
Time Zone
Select the time zone used by the API data source so that ROMA Connect can identify the data timestamp.
Timestamp Initial Value
This parameter specifies the time at which data is to be migrated for the first time. That is, only the data generated after this time point will be migrated.
Assume that Start Time Field is startTime, End Time Field is endTime, Timestamp Initial Value is 2020-11-01 12:00:00, Compensation Period is 0, and Period Settings is Default for incremental collection. If the first scheduling time of the task is 2020-11-01 13:00:00, the data collected for the first time is that the value of startTime is greater than or equal to 2020-11-01 12:00:00 and the value of endTime is less than or equal to 2020-11-01 13:00:00. For subsequent collection, the data collected each time is that the value of startTime is greater than or equal to the time when the task is successfully executed last time and the value of endTime is less than or equal to the time. Execution time of the current task.
Compensation Period (ms)
This parameter specifies the period of time (in milliseconds) which will be used to compensate for any delay in data generation at the source when ROMA Connect queries incremental data. The end time for obtaining data is the current system time minus the value you specify here.
For example, if the end time of the previous incremental migration task is 15:05, the current scheduled task is triggered at 17:00, and Compensation Period (ms) is set to 100, the time range of data to be integrated in the current incremental migration task is 15:05 to (17:00 - 100 ms).
Time Format
Select a timestamp format, for example, yyyy-MM-dd.
Period Settings
This parameter specifies the mode used for setting the time range for subsequent data integration after an incremental migration task is executed for the first time.
- Default: Data generated between the previous scheduling and current scheduling is integrated. When ROMA Connect obtains data from the source, it uses the triggering time of the two tasks as the start time and end time, respectively.
- Custom: The start time and end time are determined based on the configured period rules. This mode applies to common periodic tasks, for example, tasks executed once a day, a week, or a month.
Start Time Offset (Days)
This parameter is mandatory only if Period Settings is set to Default.
Set the number of days before the start time of data collection.
If data generated at the source changes in real time, such as alarm data, you can collect the data by setting this parameter.
Start time of data collection = Data source system time – Start time offset
Time Interval
This parameter is mandatory only if Period Settings is set to Custom.
Select the time granularity. The value must be the same as the unit configured in the task schedule so that the new data can be overwritten. For example, if Unit is set to Day in a task schedule, set this parameter to Day, indicating that data is obtained once a day.
Period
Select the time period for obtaining source data. For example, if the task is executed once a day, Time Interval is set to Day, and Period is set to Previous period, data of the previous day is incrementally integrated once. If Period is set to Current period, data of the current day is incrementally integrated once.
Right Periodic Boundary
This parameter specifies whether the end time is included in the time range for obtaining source data.
- Closed interval: The end time is included.
- Open interval: The end time is not included.
Request Parameters
Construct the parameter definition of the API request, for example, the page number and page size fields must be carried in Params or Body. Set this parameter based on the definition of the API data source.
Parse
If Paging is enabled, Parse is set to Yes by default and cannot be changed.
This parameter specifies whether ROMA Connect parses the obtained source data.
- If you select Yes, ROMA Connect parses the obtained source data based on the configured parsing rules and then integrates the data to the destination.
- If you select No, ROMA Connect transparently transmits the obtained source data and integrates the data to the destination.
Response Type
This parameter is mandatory only if Parse is set to Yes.
Select the format that will be used for the response of an API request. The value can be JSON or XML. Ensure that the format is the same as the actual response format of the API.
Data Root Field
This parameter specifies the path of the upper-layer common fields among all metadata in the data obtained from the source in JSON or XML format. Data Root Field and Parsing Path in Metadata form a complete metadata path. For details, see Description on Metadata Parsing Path Configuration.
Metadata
This parameter specifies each underlying key-value data element that is obtained from the source in JSON or XML format and needs to be integrated to the destination.
- Alias: user-defined metadata name.
- Type: data type of metadata. The value must be the same as the data type of the corresponding parameter in the response.
- Parsing Path: path of the metadata, which does not contain the data root field. For details, see Description on Metadata Parsing Path Configuration.
- Data in JSON or XML format does not contain arrays:
For example, in the following JSON data (similar to XML data), the complete path of element a is a, the complete path of element b is a.b, the complete path of element c is a.b.c, and the complete path of element d is a.b.d. Elements c and d are underlying data elements, that is, the data to be integrated to the destination.
{ "a": { "b": { "c": "xx", "d": "xx" } } }
In this scenario, three configuration solutions are available for Data Root Field and Parsing Path:
- Data Root Field is not specified.
Parsing Path of metadata c must be set to a.b.c, and Parsing Path of element d must be set to a.b.d.
- Data Root Field is set to a.
Parsing Path starts from the underlying path of element a. Parsing Path of metadata c must be set to b.c, and Parsing Path of element d must be set to b.d.
- Data Root Field is set to a.b.
Parsing Path starts from the underlying path of element b. Parsing Path of metadata c must be set to c, and Parsing Path of element d must be set to d.
- Data in JSON or XML format contains arrays:
For example, in the following JSON data (similar to XML data), the complete path of element a is a, the complete path of element b is a.b, the complete path of element c is a.b[i].c, and the complete path of element d is a.b[i].d. Elements c and d are underlying data elements, that is, the data to be integrated to the destination.
{ "a": { "b": [{ "c": "xx", "d": "xx" }, { "c": "yy", "d": "yy" } ] } }
Parsing Path of metadata c must be set to a.b[i].c, and Parsing Path of element d must be set to a.b[i].d.
Parsing Path starts from the underlying path of element a. Parsing Path of metadata c must be set to b[i].c, and Parsing Path of element d must be set to b[i].d.
Parsing Path starts from the underlying path of element b. Parsing Path of metadata c must be set to [i].c, and Parsing Path of element d must be set to [i].d.
The preceding data in JSON or XML format that contains arrays is used as an example. The following describes the configuration when the destination is API:
- In the example of pagination configuration. pageNo and pageSize are the pagination parameters of the API and need to be added to the Request Parameters.
Figure 1 API pagination configuration example
- In the example of incremental migration configuration, startTime and endTime are the time parameters of the API and need to be added to the Request Parameters.
Figure 2 API incremental migration configuration example
- In the example of metadata configuration, Data Root Field is set to a.
Figure 3 API metadata configuration example
- After configuring the source information, proceed with Configuring Destination Information.
ActiveMQ
If Integration Mode is set to Real-Time, you can select ActiveMQ as the data source type at the source.
Table 2 ActiveMQ information at the source Parameter
Instance
Select the integration application to which the ActiveMQ data source belongs. Ensure that the integration application has been configured in Connecting to Data Sources.
Data Source Type
Select ActiveMQ.
Data Source Name
Select the ActiveMQ data source that you configured in Connecting to Data Sources.
Destination Type
Select the message transfer model of the ActiveMQ data source. The value can be Topic or Queue.
Destination Name
Enter the name of a topic or queue from which to obtain data. Ensure that the topic or queue already exists.
Parse
Data Root Field
This parameter specifies the path of the upper-layer common fields among all metadata in the data obtained from the source in JSON format. Data Root Field and Parsing Path in Metadata form a complete metadata path. For details, see Description on Metadata Parsing Path Configuration.
Metadata
This parameter specifies each underlying key-value data element that is obtained from the source in JSON format and needs to be integrated to the destination.
- Type: data type of metadata. The value must be the same as the data type of the corresponding parameter in the source data.
- Data in JSON format does not contain arrays:
For example, in the following JSON data, the complete path of element a is a, the complete path of element b is a.b, the complete path of element c is a.b.c, and the complete path of element d is a.b.d. Elements c and d are underlying data elements, that is, the data to be integrated to the destination.
- Data in JSON format contains arrays:
For example, in the following JSON data, the complete path of element a is a, the complete path of element b is a.b, the complete path of element c is a.b[i].c, and the complete path of element d is a.b[i].d. Elements c and d are underlying data elements, that is, the data to be integrated to the destination.
The preceding JSON data that does not contain arrays is used as an example. The following describes the configuration when the source is ActiveMQ:
ArtemisMQ
If Integration Mode is set to Real-Time, you can select ArtemisMQ as the data source type at the source.
Table 3 ArtemisMQ information at the source Parameter
Instance
Select the integration application to which the ArtemisMQ data source belongs. Ensure that the integration application has been configured in Connecting to Data Sources.
Data Source Type
Select ArtemisMQ.
Data Source Name
Select the ArtemisMQ data source that you configured in Connecting to Data Sources.
Destination Type
Select the message transfer model of the ArtemisMQ data source. The value can be Topic or Queue.
Destination Name
Parse
Data Root Field
Metadata
The configuration when the source is ArtemisMQ is similar to that when the source is ActiveMQ. For details, see ActiveMQ configuration example.
DB2
If Integration Mode is set to Scheduled, you can select DB2 as the data source type at the source.
Table 4 DB2 information at the source Parameter
Instance
Select the integration application to which the DB2 data source belongs. Ensure that the integration application has been configured in Connecting to Data Sources.
Data Source Type
Select DB2.
Data Source Name
Select the DB2 data source that you configured in Connecting to Data Sources.
Insert SQL
This parameter specifies whether SQL statements are used to obtain source data.
- If Insert SQL is enabled, ROMA Connect obtains source data based on the entered SQL statements.
- If Insert SQL is disabled, ROMA Connect obtains source data based on the conditions configured on the GUI.
If Insert SQL is enabled, you need to enter an SQL statement for querying data. The statement must be a SELECT statement and contain the WHERE condition. The INSERT, UPDATE, DELETE, and DROP statements cannot be used. Click Check SQL to check the validity of the statement.
For example, if you enter the statement SELECT col01, col02 FROM table01 WHERE col02 IN('A', 'B', 'C') ORDER BY col01, ROMA Connect selects the col01 and col02 columns from table01, filters data rows whose values are A, B, or C in the col02 column, and sorts the data rows in sequence based on the values in the col01 column.
Table
This parameter is mandatory only if Insert SQL is disabled.
Select the data table from which data is to be obtained in the DB2 data source. Then, click Select Table Field and select only the column fields that you want to integrate and synchronize.
Field Sorting
This parameter specifies how the data to be integrated is sorted by field. To sort the integrated data, select a reference field and select Ascending or Descending.
Time Zone
Select the time zone used by the DB2 data source so that ROMA Connect can identify the data timestamp.
Timestamp
This parameter is mandatory only if Incremental Migration is enabled and Insert SQL is disabled.
Select a field of the DATE type as the timestamp, which can be used to check whether a data row meets incremental integration conditions. If the entered values of Timestamp field and Timestamp Initial Value are incomplete, full integration is used by default.
Filter
Add filter criteria for data to be integrated. Only the source data that meets the filter criteria will be integrated to the destination.
For example, the condition "and | col02 | equal | A" means that only the data rows whose values are A in the col02 column will be integrated.
Extended Metadata
This parameter is mandatory if the value of a field in the database is in JSON format and the underlying key-value data elements in the JSON field value need to be collected.
- Field Name: Select the name of the data field whose sub-elements need to be collected in the table.
- Type: data type of the data element to be collected in the JSON field value.
- Parsing Path: complete path of the data element in the JSON field value. For details, see Description on Extended Metadata Parsing Path Configuration.
In this scenario, Parsing Path of metadata c must be set to a.b.c, and Parsing Path of element d must be set to a.b.d.
In this scenario, Parsing Path of metadata c must be set to a.b[i].c, and Parsing Path of element d must be set to a.b[i].d.
- Incremental migration does not support synchronization of physical deletion operations on source data tables to the destination. Logical deletion is recommended at the source.
- For data changes at the source, the timestamp of data rows needs to be updated synchronously. ROMA Connect compares the timestamp with the task execution time to identify the data to be incrementally migrated.
The configuration when the source is DB2 is similar to that when the source is MySQL. For details, see MySQL configuration example.
DWS
If Integration Mode is set to Scheduled, you can select DWS as the data source type at the source.
Table 5 DWS information at the source Parameter
Instance
Select the integration application to which the DWS data source belongs. Ensure that the integration application has been configured in Connecting to Data Sources.
Data Source Type
Select DWS.
Data Source Name
Select the DWS data source that you configured in Connecting to Data Sources.
Insert SQL
Table
Select the data table from which data is to be obtained in the DWS data source. Then, click Select Table Field and select only the column fields that you want to integrate and synchronize.
Field Sorting
Time Zone
Select the time zone used by the DWS data source so that ROMA Connect can identify the data timestamp.
Timestamp
Select a field of the DATE type in the data table as the timestamp of source data to determine whether the data meets the incremental integration conditions.
Filter
The configuration when the source is DWS is similar to that when the source is MySQL. For details, see MySQL configuration example.
DIS
If Integration Mode is set to Real-Time, you can select DIS as the data source type at the source.
Table 6 DIS information at the source Parameter
Instance
Select the integration application to which the DIS data source belongs. Ensure that the integration application has been configured in Connecting to Data Sources.
Data Source Type
Select DIS.
Data Source Name
Select the DIS data source that you configured in Connecting to Data Sources.
Parse
Data Root Field
Data Type
Select the format of data obtained from the DIS data source. The data format must be the same as the actual data format stored in DIS.
Metadata
Time Zone
Select the time zone used by the DIS data source so that ROMA Connect can identify the data timestamp.
The configuration when the source is DIS is similar to that when the source is ActiveMQ. For details, see ActiveMQ configuration example.
FTP
If Integration Mode is set to Scheduled, you can select FTP as the data source type at the source.
Table 7 FTP information at the source Parameter
Instance
Select the integration application to which the FTP data source belongs. Ensure that the integration application has been configured in Connecting to Data Sources.
Data Source Type
Select FTP.
Data Source Name
Select the FTP data source that you configured in Connecting to Data Sources.
File Path
Enter the path of the folder to be accessed on the FTP server, for example, /data/FDI.
File Name
Enter the name of the data file from which data is to be obtained. If you do not specify this parameter, data of all files is obtained.
File Name Encoding
Select the encoding mode of the data file name.
Parse
Maximum File Size
Enter the maximum size of the file to be obtained. If the size of a file exceeds the value you specify here, the file cannot be obtained.
File Content Encoding
Select the encoding format of the data file content.
File Separator
Enter the field separator for the data file to distinguish different fields in each row of data.
Space Format Character
Enter the space characters defined in the data file so that ROMA Connect can identify the space characters in the file content. For example, if the space format is defined as a period (.), it is considered as a space when the period (.) is read during data obtaining.
Skip File Header
This parameter specifies whether to skip the file header in the data file. The file header is the first line or several lines at the beginning of a file, which helps identify and distinguish the file content.
Skipped Header Lines
This parameter is mandatory only if Skip File Header is set to Yes.
Enter the number of lines in the file header in a data file so that ROMA Connect can skip the header lines and identify the start line of the data in the file.
Migrated Data Quantity
Set the amount of data to be obtained.
- If Parse is set to Yes, this parameter indicates the number of data rows to be parsed.
- If Parse is set to No, this parameter indicates the number of files to be read.
Metadata
This parameter specifies each data field in a data file obtained from the source to be integrated to the destination. Metadata must be filled according to the sequence of the fields in the file.
The following describes the configuration when the source is FTP. The id, name, and info fields are obtained from the FTP data source and need to be integrated to the destination.
Figure 5 FTP configuration example - After configuring the source information, proceed with Configuring Destination Information.
FI HDFS
If Integration Mode is set to Scheduled, you can select FI HDFS as the data source type at the source.
Table 8 FI HDFS information at the source Parameter
Instance
Select the integration application to which the FI HDFS data source belongs. Ensure that the integration application has been configured in Connecting to Data Sources.
Data Source Type
Select FI HDFS.
Data Source Name
Select the FI HDFS data source that you configured in Connecting to Data Sources.
Separator
This parameter specifies the user-defined separator.
Storage Subpath
This parameter specifies the subpath for storing data.
Storage Block Size (M)
Select the storage block size. The value can be 64 or 128.
Storage Type
The text file type is supported.
Parse
Metadata
The configuration when the source is FI HDFS is similar to that when the source is MRS HDFS. For details, see MRS HDFS configuration example.
FI Hive
If Integration Mode is set to Scheduled, you can select FI Hive as the data source type at the source.
Table 9 FI Hive information at the source Parameter
Instance
Select the integration application to which the FI Hive data source belongs. Ensure that the integration application has been configured in Connecting to Data Sources.
Data Source Type
Select FI Hive.
Data Source Name
Select the FI Hive data source that you configured in Connecting to Data Sources.
Database Name
Select the FI Hive database name that you configured.
Table
Select the table in the FI Hive database. Then, click Select Table Field and select only the column fields that you want to integrate and synchronize.
Timestamp
Select a field of the DATE, TIME, or TIMESTAMP type in the data table as the timestamp of source data to determine whether the data meets the incremental integration conditions. If the entered values of Timestamp field and Timestamp Initial Value are incomplete, full integration is used by default.
Time Zone
Select the time zone used by the FI Hive data source so that ROMA Connect can identify the data timestamp.
Filter
The configuration when the source is FI Hive is similar to that when the source is MySQL. For details, see MySQL configuration example.
FI Kafka
If Integration Mode is set to Real-Time, you can select FI Kafka as the data source type at the source.
Table 10 FI Kafka information at the source Parameter
Instance
Select the integration application to which the FI Kafka data source belongs. Ensure that the integration application has been configured in Connecting to Data Sources.
Data Source Type
Select FI Kafka.
Data Source Name
Select the FI Kafka data source that you configured in Connecting to Data Sources.
Topic Name
Enter a topic name that is created in the FI Kafka service and starts with T_.
Parse
Data Root Field
Data Type
Select the format of data obtained from the FI Kafka data source. The data format must be the same as the actual data format stored in FI Kafka. If Parse is set to Yes, you can only select JSON. If Parse is set to No, you can select either JSON or Binary file.
Offset
Select whether to integrate the earliest message data or the latest message data.
Metadata
Time Zone
Select the time zone used by the FI Kafka data source so that ROMA Connect can identify the data timestamp.
The configuration when the source is FI Kafka is similar to that when the source is Kafka. For details, see Kafka configuration example.
GaussDB 100
If Integration Mode is set to Scheduled, you can select GaussDB 100 as the data source type at the source.
Table 11 Source GaussDB 100 information Parameter
Instance
Select the integration application to which the GaussDB 100 data source belongs. Ensure that the integration application has been configured in Connecting to Data Sources.
Data Source Type
Select GaussDB 100.
Data Source Name
Select the GaussDB 100 data source that you configured in Connecting to Data Sources.
Insert SQL
Schema
Select a schema.
Table
Select the data table from which data is to be obtained in the GaussDB 100 data source. Then, click Select Table Field and select only the column fields that you want to integrate and synchronize.
Field Sorting
Time Zone
Select the time zone used by the GaussDB 100 data source so that ROMA Connect can identify the data timestamp.
Timestamp
Filter
The configuration when the source is GaussDB 100 is similar to that when the source is MySQL. For details, see MySQL configuration example.
GaussDB 200
If Integration Mode is set to Scheduled, you can select GaussDB 200 as the data source type at the source.
Table 12 Source GaussDB 200 information Parameter
Instance
Select the integration application to which the GaussDB 200 data source belongs. Ensure that the integration application has been configured in Connecting to Data Sources.
Data Source Type
Select GaussDB 200.
Data Source Name
Select the GaussDB 200 data source that you configured in Connecting to Data Sources.
Insert SQL
Table
Select the data table from which data is to be obtained in the GaussDB 200 data source. Then, click Select Table Field and select only the column fields that you want to integrate and synchronize.
Field Sorting
Time Zone
Select the time zone used by the GaussDB 200 data source so that ROMA Connect can identify the data timestamp.
Timestamp
Filter
The configuration when the source is GaussDB 200 is similar to that when the source is MySQL. For details, see MySQL configuration example.
HANA
If Integration Mode is set to Scheduled, you can select HANA as the data source type at the source.
Table 13 HANA information at the source Parameter
Instance
Select the integration application to which the HANA data source belongs. Ensure that the integration application has been configured in Connecting to Data Sources.
Data Source Type
Select HANA.
Data Source Name
Select the HANA data source that you configured in Connecting to Data Sources.
Insert SQL
Table
Select the data table from which data is to be obtained in the HANA data source. Then, click Select Table Field and select only the column fields that you want to integrate and synchronize.
Field Sorting
Time Zone
Select the time zone used by the HANA data source so that ROMA Connect can identify the data timestamp.
Timestamp
Filter
The configuration when the source is HANA is similar to that when the source is MySQL. For details, see MySQL configuration example.
HL7
If Integration Mode is set to Real-Time, you can select HL7 as the data source type at the source.
Table 14 HL7 information at the source Parameter
Instance
Select the integration application to which the HL7 data source belongs. Ensure that the integration application has been configured in Connecting to Data Sources.
Data Source Type
Select HL7.
Data Source Name
Select the HL7 data source that you configured in Connecting to Data Sources.
Encoding Format
Select the encoding mode of data files in the HL7 data source. The value can be UTF-8 or GBK.
Metadata
This parameter specifies the data fields in HL7 messages obtained from the source to be integrated to the destination.
- Parsing Path: location of metadata in HL7 messages. For details, see the metadata path configuration description in the subsequent section.
Description on Metadata Path Configuration
MSH|^~\\&|hl7Integration|hl7Integration|||||ADT^A01|||2.3| EVN|A01|20191212155644 PID|||PATID1234^5^M11||FN^Patrick^^^MR||19700101|1|||xx Street^^NY^^Ox4DP||||||| NK1|1|FN^John^^^MR|Father||999-9999 NK1|2|MN^Georgie^^^MSS|Mother||999-9999
The metadata parsing path of HL7 messages must be set based on the Terser syntax specifications. In the preceding example HL7 message, each line represents an information segment. Each information segment starts with three uppercase letters, which are paragraph symbols of the information segment and are used to indicate content of the information segment. Information segments are separated by separators.
- |: field separator, which is used to divide information segments into different fields. Each field in an information segment is numbered starting from 1 (excluding paragraph symbols). The rest may be deduced by analogy.
- ^: component separator, which divides the field content into different components. In the fields that are divided into components, the position of a component is identified by a number, starting from 1. The rest may be deduced by analogy.
- ~: subcomponent separator, which is used to divide a component into subcomponents.
For example, in the PID information segment, if the field position of 19700101 is 7, the parsing path is /PID-7. If the field position of xx Street is 11 and the component position is 1, the parsing path is /PID-11-1.
For the information segments with the same paragraph symbol in the HL7 message, the repeated paragraph symbol is identified by adding a number enclosed by brackets after the paragraph symbol. In repeated paragraph symbols, the first is (0), the second is (1), and so on.
For example, in the NK1 information segment, "Father" is located in the first NK1 information segment, and a field location is 3, a parsing path of the NK1 information segment is NK1(0)-3. Similarly, the parsing path of Mother is NK1(1)-3.
Reading the 19700101 and xx Street fields in the preceding HL7 message is used as an example. The following describes the configuration when the source is HL7:
Figure 6 HL7 configuration example - After configuring the source information, proceed with Configuring Destination Information.
Hive
If Integration Mode is set to Scheduled, you can select Hive as the data source type at the source.
Table 15 Hive information at the source Parameter
Instance
Select the integration application to which the Hive data source belongs. Ensure that the integration application has been configured in Connecting to Data Sources.
Data Source Type
Select Hive.
Data Source Name
Select the Hive data source that you configured in Connecting to Data Sources.
Database Name
Select the database in the Hive data source.
You need to use a self-built database instead of the default database of Hive.
Table
Select the data table in the Hive data source. Then, click Select Table Field and select only the column fields that you want to integrate and synchronize.
Timestamp
Time Zone
Select the time zone used by the Hive data source so that ROMA Connect can identify the data timestamp.
Filter
The configuration when the source is Hive is similar to that when the source is MySQL. For details, see MySQL configuration example.
IBM MQ
If Integration Mode is set to Real-Time, you can select IBM MQ as the data source type at the source.
Table 16 IBM MQ information at the source Parameter
Instance
Select the integration application to which the IBM MQ data source belongs. Ensure that the integration application has been configured in Connecting to Data Sources.
Data Source Type
Select IBM MQ.
Data Source Name
Select the IBM MQ data source that you configured in Connecting to Data Sources.
Destination Type
Select the message transfer model of the IBM MQ data source. The value can be Topic or Queue.
Destination Name
Parse
Data Root Field
Metadata
The configuration when the source is IBM MQ is similar to that when the source is ActiveMQ. For details, see ActiveMQ configuration example.
Kafka
If Integration Mode is set to Real-Time, you can select Kafka as the data source type at the source. ROMA Connect MQS is a Kafka data source.
Table 17 Kafka information at the source Parameter
Instance
Select the integration application to which the Kafka data source belongs. Ensure that the integration application has been configured in Connecting to Data Sources.
Data Source Type
Select Kafka.
Data Source Name
Select the Kafka data source that you configured in Connecting to Data Sources.
Topic Name
Select the name of the topic whose data is to be obtained.
Parse
Data Root Field
Data Type
Select the format of data obtained from the Kafka data source. The data format must be the same as the actual data format stored in Kafka. If Parse is set to Yes, you can only select JSON. If Parse is set to No, you can select either JSON or Binary file.
Offset
Metadata
Time Zone
Select the time zone used by the Kafka data source so that ROMA Connect can identify the data timestamp.
The preceding JSON data that does not contain arrays is used as an example. The following describes the configuration when the source is Kafka:
LDAP
If Integration Mode is set to Scheduled, you can select LDAP as the data source type at the source.
Table 18 LDAP information at the source Parameter
Instance
Select the integration application to which the LDAP data source belongs. Ensure that the integration application has been configured in Connecting to Data Sources.
Data Source Type
Select LDAP.
Data Source Name
Select the LDAP data source that you configured in Connecting to Data Sources.
DN
This parameter specifies the distinguished name (DN) in the character string for connecting to the server, including Domain Component (DC), Common Name (CN), User ID (UID), and Organizational Unit (OU).
For example, if DN is set to CN=test,OU=roma,DC=domainname, it indicates the test object in the roma organization of the domainname domain.
Filter Criteria
Filter fields based on the LDAP syntax. For example, (|(uid=user.1*)(&(createTimestamp>=${{begin}})(createTimestamp<=${{end}}}))) indicates that objects whose UID starts with user.1 within a specified period are queried.
- ${{begin}} indicates the time when the task was executed last time.
- ${{end}} indicates the time when the task is executed this time.
Time Format
Select a time format for the filter criterion.
Metadata
The following describes the configuration when the source is LADP. The id, name, and info fields are obtained from the LADP data source and need to be integrated to the destination.
Figure 8 LADP configuration example - After configuring the source information, proceed with Configuring Destination Information.
MySQL
If Integration Mode is set to Scheduled, you can select MySQL as the data source type at the source.
Table 19 MySQL information at the source Parameter
Instance
Select the integration application to which the MySQL data source belongs. Ensure that the integration application has been configured in Connecting to Data Sources.
Data Source Type
Select MySQL.
Data Source Name
Select the MySQL data source that you configured in Connecting to Data Sources.
Insert SQL
For example, if you enter the statement SELECT col01, col02 FROM table01 WHERE col02 IN('A', 'B', 'C') ORDER BY col01, ROMA selects the col01 and col02 columns from table01, filters data rows whose values are A, B, or C in the col02 column, and sorts the data rows in sequence based on the values in the col01 column.
Table
Select the data table from which data is to be obtained in the MySQL data source. Then, click Select Table Field and select only the column fields that you want to integrate and synchronize.
Field Sorting
Time Zone
Select the time zone used by the MySQL data source so that ROMA Connect can identify the data timestamp.
Timestamp
Select a field of the DATE type as the timestamp, which can be used to check whether a data line meets data integration conditions. If the entered values of Timestamp field and Timestamp Initial Value are incomplete, full integration is used by default.
Filter
Extended Metadata
The preceding JSON data that contains arrays is used as an example. The following describes the configuration when the destination is MySQL:
- In the example of incremental migration configuration, the data table must contain a field of the DATE, TIME, or TIMESTAMP type as the timestamp field.
- In the example of extended metadata configuration, the child elements c and d are obtained from the desc field in the data table.
Figure 10 MySQL extended metadata configuration example
MongoDB
If Integration Mode is set to Scheduled, you can select MongoDB as the data source type at the source.
Table 20 MongoDB information at the source Parameter
Instance
Select the integration application to which the MongoDB data source belongs. Ensure that the integration application has been configured in Connecting to Data Sources.
Data Source Type
Select MongoDB.
Data Source Name
Select the MongoDB data source that you configured in Connecting to Data Sources.
Source Set
Select the data set to be obtained from the MongoDB data source. (The data set is equivalent to a data table in a relational database.) Then, click Select Fields in Set and select only the column fields that you want to integrate and synchronize.
Timestamp
Time Zone
Select the time zone used by the MongoDB data source so that ROMA Connect can identify the data timestamp.
The configuration when the source is MongoDB is similar to that when the source is MySQL. For details, see MySQL configuration example.
MRS Hive
If Integration Mode is set to Scheduled, you can select MRS Hive as the data source type at the source.
Table 21 MRS Hive information at the source Parameter
Instance
Select the integration application to which the MRS Hive data source belongs. Ensure that the integration application has been configured in Connecting to Data Sources.
Data Source Type
Select MRS Hive.
Data Source Name
Select the MRS Hive data source that you configured in Connecting to Data Sources.
Database Name
Select the database in the MRS Hive data source.
You need to use a self-built database instead of the default database of MRS Hive.
Table
Select the data table from which data is to be obtained in the MRS Hive data source. Then, click Select Table Field and select only the column fields that you want to integrate and synchronize.
Timestamp
Time Zone
Select the time zone used by the MRS Hive data source so that ROMA Connect can identify the data timestamp.
Filter
The configuration when the source is MRS Hive is similar to that when the source is MySQL. For details, see MySQL configuration example.
MRS HDFS
If Integration Mode is set to Scheduled, you can select MRS HDFS as the data source type at the source.
Table 22 MRS HDFS information at the source Parameter
Instance
Select the integration application to which the MRS HDFS data source belongs. Ensure that the integration application has been configured in Connecting to Data Sources.
Data Source Type
Select MRS HDFS.
Data Source Name
Select the MRS HDFS data source that you configured in Connecting to Data Sources.
Separator
Enter the field separator for the text data in the MRS HDFS data source. The separator is used to distinguish different fields in each row of data.
Storage Subpath
Enter the path of the data to be integrated in the hdfs:///hacluster directory of MRS HDFS.
Select the size of data to be read each time ROMA Connect obtains data from the MRS HDFS data source.
Storage Type
Select the storage type of data in the MRS HDFS data source. The value must be the same as the actual data storage type of the MRS HDFS data source. Currently, only Text file is available.
Parse
Metadata
This parameter specifies each data field in text data obtained from the source to be integrated to the destination. Metadata must be filled according to the sequence of the fields in the file.
The following describes the configuration when the source is MRS HDFS. The id, name, and info fields are obtained from the MRS HDFS data source and need to be integrated to the destination.
MRS HBase
If Integration Mode is set to Scheduled, you can select MRS HBase as the data source type at the source.
Table 23 MRS HBase information at the source Parameter
Instance
Select the integration application to which the MRS HBase data source belongs. Ensure that the integration application has been configured in Connecting to Data Sources.
Data Source Type
Select MRS HBase.
Data Source Name
Select the MRS HBase data source that you configured in Connecting to Data Sources.
Table
Select the data table in the MRS HBase data source. Then, click Select Table Field and select only the column fields that you want to integrate and synchronize.
MRS Kafka
If Integration Mode is set to Real-Time, you can select MRS Kafka as the data source type at the source.
Table 24 MRS Kafka information at the source Parameter
Instance
Select the integration application to which the MRS Kafka data source belongs. Ensure that the integration application has been configured in Connecting to Data Sources.
Data Source Type
Select MRS Kafka.
Data Source Name
Select the MRS Kafka data source that you configured in Connecting to Data Sources.
Topic Name
Enter a topic name that is created in the MRS Kafka service and starts with T_.
Parse
Data Root Field
This parameter specifies the path of the upper-layer common fields among all metadata in the data obtained from the source in JSON format. Data Root Field and Parsing Path in Metadata form a complete metadata path. For details, see Description on Metadata Path Configuration.
Data Type
Select the format of data obtained from the MRS Kafka data source. The data format must be the same as the actual data format stored in MRS Kafka. If Parse is set to Yes, you can only select JSON. If Parse is set to No, you can select either JSON or Binary file.
Offset
Metadata
Time Zone
The configuration when the source is MRS Kafka is similar to that when the source is Kafka. For details, see Kafka configuration example.
OBS
If Integration Mode is set to Scheduled, you can select OBS as the data source type at the source.
Table 25 OBS information at the source Parameter
Instance
Select the integration application to which the OBS data source belongs. Ensure that the integration application has been configured in Connecting to Data Sources.
Data Source Type
Select OBS.
Data Source Name
Select the OBS data source that you configured in Connecting to Data Sources.
Path
Enter the name of the object from which data is to be obtained in the OBS data source. The value of Path cannot end with a slash (/).
File Name Prefix
Enter a file name prefix. This parameter is used together with Time Format to filter the data files to be integrated.
Time Format
Select the time format to be used in the file name. This parameter is used together with File Name Prefix to filter the data files to be integrated.
Parse
- If you select Yes, ROMA Connect parses the files based on the default sequence of OBS. By default, the file with the latest time is parsed first and then integrated into the destination.
File Type
Select the format of the data file obtained from the OBS data source. The value can be txt, csv, or zip.
Field Separator
Encoding Format
Select the encoding mode of data files obtained from the OBS data source. The value can be UTF-8 or GBK.
Skip Title
This parameter specifies whether to skip the title lines in the data file. The title is the first line or several lines at the beginning of a file, which helps identify and distinguish the file content.
Title Lines
This parameter is mandatory only if Parse is set to Yes and Skip Title is set to Yes.
Enter the number of rows in the title information in the data file so that ROMA Connect can identify the start row of the data in the file.
Metadata
The following describes the configuration when the source is OBS. The id, name, and info fields are obtained from the OBS data source and need to be integrated to the destination.
Figure 12 OBS configuration example - After configuring the source information, proceed with Configuring Destination Information.
Oracle
If Integration Mode is set to Scheduled, you can select Oracle as the data source type at the source.
Table 26 Oracle information at the source Parameter
Instance
Select the integration application to which the Oracle data source belongs. Ensure that the integration application has been configured in Connecting to Data Sources.
Data Source Type
Select Oracle.
Data Source Name
Select the Oracle data source that you configured in Connecting to Data Sources.
Insert SQL
Table
Select the data table from which data is to be obtained in the Oracle data source. Then, click Select Table Field and select only the column fields that you want to integrate and synchronize.
Field Sorting
Time Zone
Select the time zone used by the Oracle data source so that ROMA Connect can identify the data timestamp.
Timestamp
Filter
Extended Metadata
The configuration when the source is Oracle is similar to that when the source is MySQL. For details, see MySQL configuration example.
PostgreSQL
If Integration Mode is set to Scheduled, you can select PostgreSQL as the data source type at the source.
Table 27 PostgreSQL information at the source Parameter
Instance
Select the integration application to which the PostgreSQL data source belongs. Ensure that the integration application has been configured in Connecting to Data Sources.
Data Source Type
Select PostgreSQL.
Data Source Name
Select the PostgreSQL data source that you configured in Connecting to Data Sources.
Insert SQL
Table
Select the data table from which data is to be obtained in the PostgreSQL data source. Then, click Select Table Field and select only the column fields that you want to integrate and synchronize.
Field Sorting
Time Zone
Select the time zone used by the PostgreSQL data source so that ROMA Connect can identify the data timestamp.
Timestamp
Filter
Extended Metadata
The configuration when the source is PostgreSQL is similar to that when the source is MySQL. For details, see MySQL configuration example.
RabbitMQ
If Integration Mode is set to Real-Time, you can select RabbitMQ as the data source type at the source.
Table 28 RabbitMQ information at the source Parameter
Instance
Select the integration application to which the RabbitMQ data source belongs. Ensure that the integration application has been configured in Connecting to Data Sources.
Data Source Type
Select RabbitMQ.
Data Source Name
Select the RabbitMQ data source that you configured in Connecting to Data Sources.
New Queue Creation
This parameter specifies whether to create a queue in the RabbitMQ data source.
- If this parameter is set to Yes, a new queue is created and data is obtained from the new queue.
- If this parameter is set to No, data is obtained from the existing queue.
Exchange Mode
This parameter is mandatory only if New Queue Creation is set to Yes.
Select a routing mode for the exchange in RabbitMQ to forward messages to the new queue.
- Direct: If the routing key in a message fully matches the queue, the message will be forwarded to the queue.
- Topic: If the routing key in a message approximately matches the queue, the message will be forwarded to the queue.
- Fanout: All messages will be forwarded to the queue.
- Headers: If the Headers attribute of a message fully matches the queue, the message will be forwarded to the queue.
Exchange Name
Enter the exchange name of the new queue in RabbitMQ.
Routing Key
This parameter is mandatory only if Exchange Mode is set to Direct or Topic.
Enter the routing key of the new queue. RabbitMQ uses the routing key as a condition and forwards messages that meet the condition to the new queue.
Message Parameters
This parameter is mandatory only if Exchange Mode is set to Headers.
Enter the Headers key-value pair of the new queue. RabbitMQ uses Headers as a condition and forwards messages that meet the condition to the new queue.
Queue Name
Enter the name of the message queue whose data is to be obtained.
- If New Queue Creation is set to Yes, enter a new queue name.
- If New Queue Creation is set to No, enter the name of an existing queue in the RabbitMQ data source.
Automatic Deletion
This parameter specifies whether a queue will be automatically deleted if no client is connected.
Persistence
This parameter specifies whether messages in a queue are stored permanently.
Parse
Metadata
- Parsing Path: full path of metadata. For details, see Description on Metadata Parsing Path Configuration.
The preceding JSON data that does not contain arrays is used as an example. The following describes the configuration when the source is RabbitMQ:
Figure 13 RabbitMQ configuration example - After configuring the source information, proceed with Configuring Destination Information.
SAP
If Integration Mode is set to Scheduled, you can select SAP as the data source type at the source.
Table 29 SAP information at the source Parameter
Instance
Select the integration application to which the SAP data source belongs. Ensure that the integration application has been configured in Connecting to Data Sources.
Data Source Type
Select SAP.
Data Source Name
Select the SAP data source that you configured in Connecting to Data Sources.
Available Function
This parameter specifies the functions that are opened by the SAP data source for remote invoking.
Click Query. In the Available Functions dialog box, enter the function name and group name to query and obtain the list of available functions of the SAP data source. In the Function List area, select the function you want to use and click OK.
- The available functions can be queried on ROMA Connect only if the function that allows remote access has been enabled in the SAP data source.
- The function name and group name support fuzzy search by prefix.
Function Name
Enter the name of the SAP function selected in Available Functions.
Request Parameters
The request parameters of the selected source function are automatically displayed. Enter the value of each request parameter based on the site requirements. The source function returns the corresponding output parameter based on the request parameter.
If the request parameter is a table-type parameter, only the first row of the parameter table is displayed. You can click Add on the right of the parameter to add parameters in other rows of the parameter table. For details, see Description on Configuration of Table-type Request Parameters.
Metadata
The output parameters (metadata) of the selected source function are automatically displayed. The metadata alias is automatically generated based on the parsing path. You can edit the metadata alias based on the site requirements. You can also delete unnecessary metadata and retain only the metadata that needs to be integrated to the destination.
Description on Configuration of Table-type Request Parameters:
The following request parameter structure is used as an example. [] indicates the table-type data, and {} indicates a row of data in the table. There are three rows of data in a parameter table, and each row of data contains two parameters.
The key of parameter b is a[i].b, and the key of parameter c is a[i].c. i indicates the row number of the parameter in the parameter table. The value 0 indicates the first row, the value 1 indicates the second row, and so on.
a: [ {b: xx, c: xx}, {b: yy, c: yy}, {b: zz, c: zz}, ]
After you select an available function, only the parameters in the first row of the a data table are displayed, that is, a[0].b and a[0].c. If you need to add the parameters of a row in the data table, add the parameters row by row in sequence. Ensure that the parameters of the previous row have been added. You are not allowed to add the parameters of only row 1 and row 3 without adding the parameters of row 2.
For example, in the preceding example, if you want to add the parameter in the second row, add a[1].b or a[1].c after a[0].c. To add the parameter in the third row, add at least one of parameters a[1].b and a[1].c in the second row after a[0].c, and then add parameter a[2].b or a[2].c in the third row.
NOTICE:
The same parameter in the same row of data cannot be added repeatedly. Otherwise, the data integration task fails to be executed.
SNMP
If Integration Mode is set to Scheduled, you can select SNMP as the data source type at the source.
Table 30 SNMP information at the source Parameter
Instance
Select the integration application to which the SNMP data source belongs. Ensure that the integration application has been configured in Connecting to Data Sources.
Data Source Type
Select SNMP.
Data Source Name
Select the SNMP data source that you configured in Connecting to Data Sources.
Data Mode
Select a data mode from the SNMP data source.
- If you select Row for Data Mode, SNMP data is parsed by row.
- If you select Column for Data Mode, SNMP data is parsed by column.
Object Identifier
This parameter is mandatory only if Data Mode is set to Column.
Enter the OID of the object to be obtained from the SNMP message. Separate multiple OIDs with commas (,).
Metadata
This parameter specifies the object (data field) to be integrated to the destination from the SNMP message data obtained from the source.
- Parsing Path: OID of metadata in the SNMP message. This parameter is mandatory only if Data Mode is set to Row.
The following describes the configuration when the destination is SNMP:
- When Data Model is set to Row, user indicates obtaining system contact information and location indicates obtaining server location information.
Figure 14 Configuration example when the data model is Row
- When Data Model is set to Column, the info column contains the system contact information and server location information.
SQL Server
If Integration Mode is set to Scheduled, you can select SQL Server as the data source type at the source.
Table 31 SQL Server information at the source Parameter
Instance
Select the integration application to which the SQL Server data source belongs. Ensure that the integration application has been configured in Connecting to Data Sources.
Data Source Type
Select SQL Server.
Data Source Name
Select the SQL Server data source that you configured in Connecting to Data Sources.
Insert SQL
Table
This parameter needs to be set only when Insert SQL is disabled.
Select the data table in the SQL Server data source. Then, click Select Table Field and select only the column fields that you want to integrate and synchronize.
Field Sorting
Time Zone
Select the time zone used by the SQL Server data source so that ROMA Connect can identify the data timestamp.
Timestamp
This parameter specifies the time at which data is to be migrated for the first time. That is, only the data generated after this time point will be integrated.
Filter
Extended Metadata
The configuration when the source is SQL Server is similar to that when the source is MySQL. For details, see MySQL configuration example.
If Integration Mode is set to Scheduled, you can select TaurusDB as the data source type at the source.
Table 32 TaurusDB information at the source Parameter
Instance
Select the integration application to which the TaurusDB data source belongs. Ensure that the integration application has been configured in Connecting to Data Sources.
Data Source Type
Select TaurusDB.
Data Source Name
Select the TaurusDB data source that you configured in Connecting to Data Sources.
Insert SQL
Table
Select the data table from which data is to be obtained in the TaurusDB data source. Then, click Select Table Field and select only the column fields that you want to integrate and synchronize.
Field Sorting
Time Zone
Select the time zone used by the TaurusDB data source so that ROMA Connect can identify the data timestamp.
Timestamp
Filter
Extended Metadata
The preceding JSON data that contains arrays is used as an example. The following describes the configuration when the destination is TaurusDB:
- In the example of incremental migration configuration, the data table must contain a field of the DATE type as the timestamp field.
Figure 15 TaurusDB incremental migration configuration example
Figure 16 TaurusDB extended metadata configuration example
WebSocket
If Integration Mode is set to Real-Time, you can select WebSocket as the data source type at the source.
Table 33 WebSocket information at the source Parameter
Instance
Select the integration application to which the WebSocket data source belongs. Ensure that the integration application has been configured in Connecting to Data Sources.
Data Source Type
Select WebSocket.
Data Source Name
Select the WebSocket data source that you configured in Connecting to Data Sources.
Data Root Field
Heartbeat Mechanism
This parameter specifies whether the heartbeat mechanism is enabled between ROMA Connect and the WebSocket data source to ensure connection validity.
Heartbeat Message
This parameter is mandatory only if Heartbeat Mechanism is set to Yes.
This parameter specifies the message content carried in heartbeat packets sent by ROMA Connect to the WebSocket data source.
Heartbeat Sending Interval
This parameter specifies the interval for the ROMA Connect to send heartbeat packets to the WebSocket data source.
Parse
Metadata
The preceding JSON data that does not contain arrays is used as an example. The following describes the configuration when the source is WebSocket:
Figure 17 WebSocket configuration example - After configuring the source information, proceed with Configuring Destination Information.
Custom
If Integration Mode is set to Scheduled, you can select a custom data source at the source. ROMA Connect communicates with custom data sources through standard RESTful APIs.
- On the Create Task page, configure source information.
Table 34 Custom data source information Parameter
Instance
Select the ROMA Connect instance that is being used.
Integration Application
Select the integration application to which the custom data source belongs. Ensure that the integration application has been configured in Connecting to Data Sources.
Data Source Type
Select a custom data source type.
Data Source Name
Select the custom data source that you configured in Connecting to Data Sources.
Paging
Specifies whether data is returned on multiple pages when ROMA Connect sends a request to the custom data source to obtain data. Multiple data records can be returned for one API request.
- If Paging is enabled, all data that meets the conditions is displayed on multiple pages based on a fixed number of records on each page. ROMA Connect obtains data on one page each time and obtains all data by sending multiple requests.
- If Paging is disabled, ROMA Connect obtains all data that meets the conditions through one API request.
Start Page
This parameter is mandatory only if Paging is enabled.
Enter the start page number for paging. The value can be 0 or 1. Set this parameter based on the original definition of the API.
Page Size
Enter the maximum number of data records on each page. Set this parameter based on the original definition of the API.
Time Zone
Select the time zone used by the custom data source so that ROMA Connect can identify the data timestamp.
Start Time
Parse
Metadata
In addition to the preceding parameters, different custom data sources define different reader parameters. Set the parameters based on the original definition specifications of the connector. You can locate the connector used by the custom data source on the Assets page of the ROMA Connect console and view the reader parameter definition of the connector.
The preceding JSON data that does not contain arrays is used as an example. The following figure describes the configuration when the source is a custom data source. In the example, the value of key is the reader parameter defined in the connector.
Figure 18 Custom data source configuration example - After configuring the source information, proceed with Configuring Destination Information.
