On this page
Connecting to a HIVE Data Source
Updated on 2023-07-26 GMT+08:00
Overview
ROMA Connect can use HIVE as a data source to create data APIs. Before using the HIVE data source, you need to connect it to ROMA Connect.
Each connected data source must belong to an integration application. Before connecting a data source, ensure that an integration application is available. Otherwise, create an integration application in advance.
  1. Log in to the ROMA Connect console. On the Instances page, click View Console next to a specific instance.
  2. In the navigation pane on the left, choose Data Sources. In the upper right corner of the page, click Access Data Source.
  3. On the Default tab page, select HIVE and click Next.
  4. Configure the data source connection information.
    Table 1 Data source connection information
    Name
    Enter a data source name. It is recommended that you enter a name based on naming rules to facilitate search.
    Integration Application
    Select the integration application to which the data source belongs.
    Enter the descriptive information.
    Connection Mode
    Select the connection mode for the database.
    • Default: The default mode is used for the database connection.
    • Professional: The JDBC mode is used for the database connection.
    Connection Address
    This parameter is mandatory only if Connection Mode is set to Default.
    Enter the IP address and port number for connecting the database.
    Database Name
    Enter the name of the database to be connected.
    Connection String
    This parameter is mandatory only if Connection Mode is set to Professional.
    Enter the JDBC connection string of the HIVE database, for example, jdbc:hive2://{hostname}:{port}/{dbname}.
    • {hostname} indicates the connection address of the database.
    • {port} indicates the port of the database.
    • {dbname} indicates the name of the database to be connected.
    Username
    Enter the username used to connect to the database.
    Password
    Enter the password used to connect to the database.
    The connection configuration of the HIVE data source is similar to that of the MySQL data source. For details, see Connecting to a MySQL Data Source.
  5. Click Check Connectivity to check the connectivity between ROMA Connect and the data source.
    • If the test result is Data source connected successfully, go to the next step.
    • If the test result is Failed to connect to the data source, check the data source status and connection parameters, and click Recheck until the connection is successful.
  6. Click Create.
