Appendix: Extended Swagger Definition of APIs
Updated on 2022-02-21 GMT+08:00
On the basis of the basic Swagger definition, ROMA Connect defines the extended definition of APIs, such as the authentication mode and backend service definition. This section describes the extended definitions of APIs.
1: x-apigateway-auth-type
Meaning: Swagger-based apiKey authentication format, which defines an authentication mode provided by ROMA Connect.
Scope of effect: Security Scheme Object
Example
securityDefinitions:
  customize-name-iam:
    type: "apiKey"
    in: "header"
    x-apigateway-auth-type: "IAM"
  customize-name-app:
    type: "apiKey"
    in: "header"
    x-apigateway-auth-type: "AppSigv1"
  customize-name-iam-none:
    type: "apiKey"
    in: "header"
    x-apigateway-auth-type: "IAM_NONE"
Table 1 Parameter description
Mandatory
Type
type
Yes
String
Authentication type. Only apiKey is supported.
name
Yes
String
Name of the parameter for authentication.
  • When x-apigateway-auth-type is set to AppSigv1, set name to Authorization.
  • When x-apigateway-auth-type is set to IAM or IAM_NONE, set name to unused.
in
Yes
String
Location of the parameter. Only header is supported.
description
No
String
Description of the parameter.
Yes
String
APIC authentication mode. AppSigv1, IAM, and IAM_NONE are supported.
2: x-apigateway-request-type
Meaning: API request type, which can be public or private.
Scope of effect: Operation Object
Example
paths:
  '/path':
    get:
      x-apigateway-request-type: 'public'
Table 2 Parameter description
Mandatory
Type
Yes
String
API visibility. The options include public and private.
  • public: The API can be made available for sale.
  • private: The API will not be available for sale.
3: x-apigateway-match-mode
Meaning: Request URL matching mode, which can be NORMAL or SWA.
Example
paths:
  '/path':
    get:
      x-apigateway-match-mode: 'SWA'
Table 3 Parameter description
Mandatory
Type
Yes
String
Matching mode of the API request path. The value can be SWA or NORMAL.
  • SWA: prefix match. For example, if the request path is set to /test/AA and the matching mode is set to SWA, the API can be accessed using /test/AA/BB or /test/AA/CC but cannot be accessed using /test/AACC.
  • NORMAL: exact match.
4: x-apigateway-cors
Meaning: Specifies whether APIs defined by ROMA Connect support CORS.
Example
paths:
  '/path':
    get:
      x-apigateway-cors: true
Table 4 Parameter description
Mandatory
Type
x-apigateway-cors
No
Boolean
Whether CORS is supported.
For the API request for enabling CORS, the headers listed in the following table will be added to the response.
Parameter Name
Parameter Value
Access-Control-Max-Age
172800
Maximum time the response of a preflight request can be cached.
Access-Control-Allow-Origin
Domain that can be accessed. The asterisk (*) indicates that requests from any domain are allowed.
Access-Control-Allow-Headers
X-Sdk-Date, X-Sdk-Nonce, X-Proxy-Signed-Headers, X-Sdk-Content-Sha256, X-Forwarded-For, Authorization, Content-Type, Accept, Accept-Ranges, Cache-Control, Range
Header information fields that can be used in API requests.
Access-Control-Allow-Methods
GET, POST, PUT, DELETE, HEAD, OPTIONS, PATCH
HTTP methods allowed by the API request.
5: x-apigateway-any-method
Meaning: API request method used by default if no HTTP request method is specified.
Scope of effect: Path Item Object
Example
paths:
  '/path':
    get:
      produces:
        - application/json
      responses:
        "200":
          description: "get response"
    x-apigateway-any-method:
      produces:
        - application/json
      responses:
        "200":
          description: "any response"
6: x-apigateway-backend
Meaning: API backend definition.
Example
paths:
  '/users/{userId}':
    get:
      produces:
        - "application/json"
      responses:
        default:
          description: "default response"
      x-apigateway-request-type: "public"
      x-apigateway-backend:
        type: "backend endpoint type"
Table 5 Parameter description
Mandatory
Type
type
Yes
String
Backend service type. HTTP, HTTP-VPC, and MOCK are supported.
parameters
No
x-apigateway-backend.parameters
Backend parameters.
httpEndpoints
No
x-apigateway-backend.httpEndpoints
HTTP backend service definition.
httpVpcEndpoints
No
x-apigateway-backend.httpVpcEndpoints
HTTP-VPC backend service definition.
functionEndpoints
No
x-apigateway-backend.functionEndpoints
Function backend service definition.
mockEndpoints
No
x-apigateway-backend.mockEndpoints
Mock backend service definition.
6.1: x-apigateway-backend.parameters
Scope of effect: x-apigateway-backend
Example
paths:
  '/users/{userId}':
    get:
      produces:
      parameters:
        - name: "X-Auth-Token"
          description: "authorization token"
          type: "string"
          in: "header"
          required: true
        - name: "userId"
          description: "user name"
          type: "string"
          in: "path"
          required: true
      responses:
        default:
        type: "HTTP"
        parameters:
          - name: "userId"
            value: "userId"
            in: "query"
            origin: "REQUEST"
          - name: "X-Invoke-User"
            value: "apigateway"
            in: "header"
            origin: "CONSTANT"
            description: "invoke user"
Table 6 Parameter description
Mandatory
Type
name
Yes
String
Parameter name, which consists of a maximum of 32 bytes, starting with a letter. Only letters, digits, periods (.), hyphens (-), and underscores (_) are allowed.
The names of header parameters are not case-sensitive.
value
Yes
String
Parameter value, which is a parameter name if the parameter comes from a request.
in
Yes
String
Parameter location, which can be header, query, or path.
origin
Yes
String
Parameter mapping source. REQUEST and CONSTANT are supported.
description
No
String
Parameter description.
6.2: x-apigateway-backend.httpEndpoints
Meaning: HTTP backend service definition.
Example
paths:
  '/users/{userId}':
    get:
      produces:
      parameters:
          type: "string"
          in: "header"
          required: true
      responses:
        default:
        type: "HTTP"
        httpEndpoints:
          address: "www.example.com"
          scheme: "http"
          method: "GET"
          path: "/users"
          timeout: 30000
Table 7 Parameter description
Mandatory
Type
address
Yes
Array
Backend service address. The format is <Domain name or IP address>:[Port number]
scheme
Yes
String
Backend request protocol. HTTP and HTTPS are supported.
method
Yes
String
Backend request method. GET, POST, PUT, DELETE, HEAD, OPTIONS, PATCH, and ANY are supported.
path
Yes
String
Backend request path, which can contain variables.
timeout
No
Number
Backend request timeout in milliseconds. The value ranges from 1 to 60,000, and the default value is 5000.
6.3: x-apigateway-backend.httpVpcEndpoints
Meaning: HTTP-VPC backend service definition.
Example
paths:
  '/users/{userId}':
    get:
      produces:
      parameters:
          type: "string"
          in: "header"
          required: true
      responses:
        default:
        type: "HTTP-VPC"
        httpVpcEndpoints:
          scheme: "http"
          method: "GET"
          path: "/users"
          timeout: 30000
Table 8 Parameter description
Mandatory
Type
name
Yes
Array
VPC channel name.
scheme
Yes
String
method
Yes
String
path
Yes
String
timeout
No
Number
6.4: x-apigateway-backend.functionEndpoints
Meaning: FUNCTION backend service definition.
Example
paths:
  '/users/{userId}':
    get:
      produces:
      parameters:
          type: "string"
          in: "header"
          required: true
      responses:
        default:
        type: "FUNCTION"
        functionEndpoints:
          version: "v1"
          function-urn: ""
          invocation-type: "synchronous"
          timeout: 30000
Table 9 Parameter description
Mandatory
Type
function-urn
Yes
String
Function URN.
version
Yes
String
Function version.
invocation-type
Yes
String
Function invocation type. async or sync are supported.
timeout
No
Number
Function timeout in milliseconds. The value ranges from 1 to 60,000, and the default value is 5000.
6.5: x-apigateway-backend.mockEndpoints
Meaning: Mock backend service definition.
Example
paths:
  '/users/{userId}':
    get:
      produces:
      parameters:
          type: "string"
          in: "header"
          required: true
      responses:
        default:
        type: "MOCK"
        mockEndpoints:
          result-content: "mocked"
Table 10 Parameter description
Mandatory
Type
result-content
Yes
String
Mock response.
7: x-apigateway-backend-policies
Meaning: API backend policy.
Example
paths:
  '/users/{userId}':
    get:
      produces:
      responses:
        default:
      x-apigateway-backend-policies:
        - type: "backend endpoint type"
          name: "backend policy name"
          conditions:
            - type: "equal/enum/pattern",
              value: "string",
              origin: "source/request_parameter",
              parameter_name: "string"
Table 11 Parameter description
Mandatory
Type
type
Yes
String
name
Yes
String
Name
parameters
No
Backend parameters.
httpEndpoints
No
HTTP service definition.
httpVpcEndpoints
No
HTTP-VPC service definition.
functionEndpoints
No
Function service definition.
mockEndpoints
No
Mock service definition.
conditions
Yes
x-apigateway-backend-policies.conditions
Backend policy condition.
7.1: x-apigateway-backend-policies.conditions
Scope of effect: x-apigateway-backend-policies
Example
paths:
  '/users/{userId}':
    get:
      produces:
      responses:
        default:
          conditions:
              value: "string",
Table 12 Parameter description
Mandatory
Type
type
Yes
String
Policy condition type. equal, enum, and pattern are supported.
value
Yes
String
Policy condition value.
origin
Yes
String
Policy condition source. source and request are supported.
parameter
No
String
Input parameter name if the origin parameter is set to request.
8: x-apigateway-ratelimit
Meaning: Request throttling policy.
Example
paths:
  '/path':
    get:
      x-apigateway-ratelimit: 'customRatelimitName'
Table 13 Parameter description
Mandatory
Type
No
String
Name of the referenced request throttling policy. Set this parameter to customRatelimitName.
9: x-apigateway-ratelimits
Meaning: Mapping between a request throttling policy name and limit values.
Scope of effect: Swagger Object
Example
x-apigateway-ratelimits:
  customRatelimitName:
    api-limit: 200
    app-limit: 200
    user-limit: 200
    ip-limit: 200
    interval: 1
    unit: second/minute/hour
    shared: true
    special:
      - type: APP
        limit: 100
        instance: xxxxxxxxx
Table 14 Parameter description
Mandatory
Type
customRatelimitName
No
x-apigateway-ratelimits.policy
Custom request throttling policy. To use a request throttling policy, set x-apigateway-ratelimit to the name of the policy.
9.1: x-apigateway-ratelimits.policy
Meaning: Definition of a request throttling policy.
Scope of effect: x-apigateway-ratelimits
Example
    api-limit: 200
    app-limit: 200
    user-limit: 200
    ip-limit: 200
    interval: 1
    unit: MINUTE
    shared: false
    special:
      - type: USER
        limit: 100
        instance: xxxxxxx
Table 15 Parameter description
Mandatory
Type
api-limit
Yes
Number
Maximum number of times an API can be called.
user-limit
No
Number
Number of times the API can be called by a user.
app-limit
No
Number
Number of times the API can be called by an app.
ip-limit
No
Number
Number of times the API can be called by an IP address.
interval
Yes
Number
Throttling period.
unit
Yes
String
Throttling unit, which can be SECOND, MINUTE, HOUR, or DAY.
shared
No
Boolean
Whether to share the throttling limits among APIs.
special
No
x-apigateway-ratelimits.policy.special
Special request throttling policy.
9.2: x-apigateway-ratelimits.policy.special
Meaning: Definition of a special request throttling policy.
Scope of effect: x-apigateway-ratelimits.policy
Example
    api-limit: 200
    app-limit: 200
    user-limit: 200
    ip-limit: 200
    interval: 1
    unit: MINUTE
    shared: false
    special:
      - type: USER
        limit: 100
        instance: xxxxxxxx
Table 16 Parameter description
Mandatory
Type
type
Yes
String
Excluded request throttling type, which can be APP or USER.
limit
Yes
Number
Access limit.
instance
Yes
String
Excluded app or user
10: x-apigateway-access-control
Meaning: Access control policy.
Example
paths:
  '/path':
    get:
      x-apigateway-access-control: 'customAccessControlName'
Table 17 Parameter description
Mandatory
Type
No
String
Name of the referenced access control policy. Set this parameter to customAccessControlName.
11: x-apigateway-access-controls
Meaning: Mapping between an access control policy name and limit settings.
Example
x-apigateway-access-controls:
  customAccessControlName:
    acl-type: "DENY"
    entity-type: "IP"
    value: 127.0.0.1,192.168.0.1/16
Table 18 Parameter description
Mandatory
Type
No
x-apigateway-access-controls.policy
Custom access control policy. To use an access control policy, set x-apigateway-access-control to the name of the policy.
11.1: x-apigateway-access-controls.policy
Meaning: Definition of an access control policy.
Scope of effect: x-apigateway-access-controls
Example
    acl-type: "DENY"
    entity-type: "IP"
Table 19 Parameter description
Mandatory
Type
acl-type
Yes
String
Access control effect. The options include PERMIT and DENY.
entity-type
Yes
String
Access control object. Only IP addresses are supported.
value
Yes
String
Access control policy values. Use commas (,) to separate multiple values.
12: x-apigateway-roma-app
Meaning: Integration application bound to the API.
Example
paths:
  '/path':
    get:
      x-apigateway-roma-app: 'romaAppName'
Table 20 Parameter description
Mandatory
Type
Yes
String
Name of the integration application bound to the API.
