On this page
Show all
Creating a Parameter Template
Updated on 2023-07-06 GMT+08:00
You can use database parameter templates to manage the DB engine configuration. A database parameter template acts as a container for engine configuration values that can be applied to one or more DB instances.
This default template contains DB engine defaults and system defaults that are configured based on the engine, compute class, and allocated storage of the instance. You cannot modify the parameter settings of a default parameter template. You must create your own parameter template to change parameter settings.
NOTICE:
Not all DB engine parameters can be changed in a custom parameter template.
If you want to use your custom parameter template, you simply create a parameter template and select it when you create a DB instance or apply it to an existing DB instance following the instructions provided in section Applying a Parameter Template.
When you have already created a parameter template and want to include most of the custom parameters and values from that template in a new parameter template, you can replicate that parameter template following the instructions provided in section Replicating a Parameter Template.
The following are the key points you should know when using parameters in a parameter template:
  • When you change a dynamic parameter value in a parameter template and save the change, the change takes effect immediately. When you change a static parameter value in a parameter template and save the change, the change will take effect only after you manually reboot the DB instances to which the parameter template applies.
  • Improper parameter settings may have unintended adverse effects, including degraded performance and system instability. Exercise caution when modifying database parameters and you need to back up data before modifying parameters in a parameter template. Before applying parameter template changes to a production DB instance, you should try out these changes on a test DB instance.
RDS does not share parameter template quotas with DDS.
You can create a maximum of 100 parameter templates for RDS DB instances. All RDS DB engines share the parameter template quota.
  2. Click in the upper left corner and select a region and a project.
  3. Click Service List. Under Database, click Relational Database Service. The RDS console is displayed.
  4. On the Parameter Template Management page, click Create Parameter Template.
  5. In the displayed dialog box, configure required information and click OK.
    • Select a DB engine for the parameter template.
    • The template name must consist of 1 to 64 characters. It can contain only uppercase letters, lowercase letters, digits, hyphens (-), underscores (_), and periods (.).
    • The description consists of a maximum of 256 characters and cannot contain carriage return characters or the following special characters: >!<"&'=
