- What's New
- Function Overview
- Product Bulletin
Service Overview
- Infographics
- What Is DMS for RabbitMQ?
- Product Advantages
- Application Scenarios
- Specifications
- Comparing RabbitMQ, Kafka, and RocketMQ
- Comparing RabbitMQ AMQP-0-9-1 with Open-Source RabbitMQ
- Comparing RabbitMQ Versions
- Related Services
- Security
- Notes and Constraints
- Basic Concepts
- Exchanges
- Permissions Management
- Billing
- Getting Started
User Guide
- Process of Using RabbitMQ
- Buying a RabbitMQ Instance
- Configuring Virtual Hosts
- Accessing a RabbitMQ Instance
- Managing Messages
- Advanced Features
Managing Instances
- Viewing and Modifying Basic Information of a RabbitMQ Instance
- Viewing RabbitMQ Client Connection Addresses
- Managing RabbitMQ Instance Tags
- Configuring RabbitMQ Recycling Policies
- Resetting the RabbitMQ Instance Password
- Enabling RabbitMQ Plug-ins
- Exporting the RabbitMQ Instance List
- Deleting a RabbitMQ Instance
- Logging In to RabbitMQ Management UI
- Modifying RabbitMQ Instance Specifications
- Migrating RabbitMQ Services
- Testing Instance Performance
- Applying for Increasing RabbitMQ Quotas
- Viewing Metrics and Configuring Alarms
- Viewing RabbitMQ Audit Logs
Best Practices
- RabbitMQ Best Practices
- Automatic Recovery of a RabbitMQ Client from Network Exceptions
- Automatic Consumer Reconnection After a RabbitMQ Node Restart
- Improving RabbitMQ Performance
- Configuring Queue Load Balancing
- Deduplicating Messages Through Message Idempotence
- Suggestions on Using DMS for RabbitMQ Securely
- Developer Guide
API Reference
- Before You Start
- API Overview
- Calling APIs
- Getting Started
- APIs V2 (Recommended)
- Out-of-Date APIs
- Appendix
- Change History
- SDK Reference
Instances
- What RabbitMQ Version Does DMS for RabbitMQ Use?
- What SSL Version Does DMS for RabbitMQ Use?
- Why Can't I View the Subnet and Security Group Information During Instance Creation?
- How Are Requests Evenly Distributed to Each VM of a Cluster RabbitMQ Instance?
- Do Queues Inside a Cluster RabbitMQ Instance Have Any Redundancy Backup?
- Does DMS for RabbitMQ Support Data Persistence? How Do I Perform Scheduled Data Backups?
- How Do I Obtain the Certificate After SSL Has Been Enabled?
- Can I Change the SSL Setting of a RabbitMQ Instance?
- Can RabbitMQ Instances Be Scaled Up?
- Does RabbitMQ Support Two-Way Authentication?
- Does DMS for RabbitMQ Support CPU and Memory Upgrades?
- How Do I Disable the RabbitMQ Management UI?
- Can I Change the AZ for an Instance?
- How Do I Obtain the Region ID?
- Why Can't I Select Two AZs?
- How to Change Single-node RabbitMQ Instances to Cluster Ones?
- Can I Change the VPC and Subnet After a RabbitMQ Instance Is Created?
Connections
- How Do I Configure a Security Group?
- Why Does a Client Fail to Connect to a RabbitMQ Instance?
- Does DMS for RabbitMQ Support Public Access?
- Does DMS for RabbitMQ Support Cross-Region Deployment?
- Do RabbitMQ Instances Support Cross-VPC Access?
- Do RabbitMQ Instances Support Cross-Subnet Access?
- What Should I Do If I Fail to Access a RabbitMQ Instance with SSL Encryption?
- Can I Access a RabbitMQ Instance Using DNAT?
- Why Can't I Open the Management Web UI?
- Can a Client Connect to Multiple Virtual Hosts of a RabbitMQ Instance?
- Why Does a RabbitMQ Cluster Have Only One Connection Address?
- Do RabbitMQ Instances Support the Ping Command?
- Messages
- Monitoring & Alarm
Instances
- Videos
More Documents
- Getting Started
- Managing Messages
- Advanced Features
Managing Instances
- Using the rabbitmq_tracing Plug-in
Instances
Connections
- Messages
Instances
- Change History
- API Reference (ME-Abu Dhabi Region)
- Preparing the Environment
- Buying an Instance
- Operating RabbitMQ Instances
- Quotas
- Monitoring
- Auditing
Instances
- What If One RabbitMQ VM Fails to Be Restarted When a Cluster RabbitMQ Instance Is Being Restarted?
- Does DMS for RabbitMQ Support MQTT?
- How Do I Clear Queue Data?
Connections
- Does DMS for RabbitMQ Support Cross-VPC Access?
- Does DMS for RabbitMQ Support Cross-Subnet Access?
- Plug-ins
- Messages
Instances
- Change History
- API Reference (Kuala Lumpur Region)
Creating a RabbitMQ Exchange
Exchanges receive and assign messages. Producers send messages to exchanges first, rather than directly to queues. Exchanges route messages to one or more queues based on routing keys. If there are no matching queues, the messages are discarded.
This section describes how to create an exchange on the console. For RabbitMQ 3.x.x instances, seven exchanges are created by default after virtual host creation. These exchanges include (AMQP default), amq.direct, amq.fanout, amq.headers, amq.match, amq.rabbitmq.trace, and amq.topic.
A virtual host has been created.
- Log in to the console.
- In the upper left corner, click
and select a region.
Select the region where your RabbitMQ instance is.
- Click
and choose Application > Distributed Message Service for RabbitMQ to open the console of DMS for RabbitMQ.
- Click an instance name to go to the instance details page.
- In the navigation pane, choose Virtual Hosts.
- Click a virtual host name.
- On the Exchange tab page, click Create Exchange. The Create Exchange dialog box is displayed.
- Configure the exchange name and other parameters by referring to Table 1.
Table 1 Exchange parameters Parameter
Name
When creating an exchange, you can modify the automatically generated exchange name. Naming rules: 3–128 characters and only letters, digits, percent signs (%), vertical bars (|), hyphens (-), underscores (_), slashes (/), or backslashes (\).
The name cannot be changed once the exchange is created.
Type
Select a routing type. For details, see .
- direct: Exchanges route messages to matching queues based on the routing keys.
- fanout: Exchanges route messages to all bound queues.
- topic: Exchanges route messages to queues based on routing key wildcard matching.
- headers: Exchanges are related to the message headers. Routing keys are not used. Exchanges route messages based on matching between key-value pairs in the message headers and the binding (a key-value pair).
Auto-Delete
Indicates whether to enable automatic exchange deletion.
- Enabled: The exchange will be automatically deleted when the last bound queue unbound from the exchange.
- Disabled: The exchange will not be deleted when the last bound queue unbound from the exchange.
Persistence
Indicates whether to enable exchange persistence.
- Enabled: The exchange survives server restart.
- Disabled: The exchange will be deleted after server restarts and needs to be recreated.
Internal
Indicates whether exchanges are for internal use.
- Yes: An exchange can only bind another exchange instead of a queue.
- No: Exchanges can bind exchanges and queues.
- Click OK.
View the created exchange on the Exchange tab page.
