- What's New
- Function Overview
- Product Bulletin
Service Overview
- Infographics
- What Is DMS for RabbitMQ?
- Product Advantages
- Application Scenarios
- Specifications
- Comparing RabbitMQ, Kafka, and RocketMQ
- Comparing RabbitMQ AMQP-0-9-1 with Open-Source RabbitMQ
- Comparing RabbitMQ Versions
- Related Services
- Security
- Notes and Constraints
- Basic Concepts
- Exchanges
- Permissions Management
- Billing
- Getting Started
User Guide
- Process of Using RabbitMQ
- Buying a RabbitMQ Instance
- Configuring Virtual Hosts
- Accessing a RabbitMQ Instance
- Managing Messages
- Advanced Features
Managing Instances
- Viewing and Modifying Basic Information of a RabbitMQ Instance
- Viewing RabbitMQ Client Connection Addresses
- Managing RabbitMQ Instance Tags
- Configuring RabbitMQ Recycling Policies
- Resetting the RabbitMQ Instance Password
- Enabling RabbitMQ Plug-ins
- Exporting the RabbitMQ Instance List
- Deleting a RabbitMQ Instance
- Logging In to RabbitMQ Management UI
- Modifying RabbitMQ Instance Specifications
- Migrating RabbitMQ Services
- Testing Instance Performance
- Applying for Increasing RabbitMQ Quotas
- Viewing Metrics and Configuring Alarms
- Viewing RabbitMQ Audit Logs
Best Practices
- RabbitMQ Best Practices
- Automatic Recovery of a RabbitMQ Client from Network Exceptions
- Automatic Consumer Reconnection After a RabbitMQ Node Restart
- Improving RabbitMQ Performance
- Configuring Queue Load Balancing
- Deduplicating Messages Through Message Idempotence
- Suggestions on Using DMS for RabbitMQ Securely
- Developer Guide
API Reference
- Before You Start
- API Overview
- Calling APIs
- Getting Started
- APIs V2 (Recommended)
- Out-of-Date APIs
- Appendix
- Change History
- SDK Reference
Instances
- What RabbitMQ Version Does DMS for RabbitMQ Use?
- What SSL Version Does DMS for RabbitMQ Use?
- Why Can't I View the Subnet and Security Group Information During Instance Creation?
- How Are Requests Evenly Distributed to Each VM of a Cluster RabbitMQ Instance?
- Do Queues Inside a Cluster RabbitMQ Instance Have Any Redundancy Backup?
- Does DMS for RabbitMQ Support Data Persistence? How Do I Perform Scheduled Data Backups?
- How Do I Obtain the Certificate After SSL Has Been Enabled?
- Can I Change the SSL Setting of a RabbitMQ Instance?
- Can RabbitMQ Instances Be Scaled Up?
- Does RabbitMQ Support Two-Way Authentication?
- Does DMS for RabbitMQ Support CPU and Memory Upgrades?
- How Do I Disable the RabbitMQ Management UI?
- Can I Change the AZ for an Instance?
- How Do I Obtain the Region ID?
- Why Can't I Select Two AZs?
- How to Change Single-node RabbitMQ Instances to Cluster Ones?
- Can I Change the VPC and Subnet After a RabbitMQ Instance Is Created?
Connections
- How Do I Configure a Security Group?
- Why Does a Client Fail to Connect to a RabbitMQ Instance?
- Does DMS for RabbitMQ Support Public Access?
- Does DMS for RabbitMQ Support Cross-Region Deployment?
- Do RabbitMQ Instances Support Cross-VPC Access?
- Do RabbitMQ Instances Support Cross-Subnet Access?
- What Should I Do If I Fail to Access a RabbitMQ Instance with SSL Encryption?
- Can I Access a RabbitMQ Instance Using DNAT?
- Why Can't I Open the Management Web UI?
- Can a Client Connect to Multiple Virtual Hosts of a RabbitMQ Instance?
- Why Does a RabbitMQ Cluster Have Only One Connection Address?
- Do RabbitMQ Instances Support the Ping Command?
- Messages
- Monitoring & Alarm
Instances
- Videos
More Documents
- Getting Started
- Managing Messages
- Advanced Features
Managing Instances
- Using the rabbitmq_tracing Plug-in
Instances
Connections
- Messages
Instances
- Change History
- API Reference (ME-Abu Dhabi Region)
- Preparing the Environment
- Buying an Instance
- Operating RabbitMQ Instances
- Quotas
- Monitoring
- Auditing
Instances
- What If One RabbitMQ VM Fails to Be Restarted When a Cluster RabbitMQ Instance Is Being Restarted?
- Does DMS for RabbitMQ Support MQTT?
- How Do I Clear Queue Data?
Connections
- Does DMS for RabbitMQ Support Cross-VPC Access?
- Does DMS for RabbitMQ Support Cross-Subnet Access?
- Plug-ins
- Messages
Instances
- Change History
- API Reference (Kuala Lumpur Region)
Configuring RabbitMQ Quorum Queues
Quorum queues provide the queue replication capability to ensure high data availability and security. Quorum queues can be used to replicate queue data between RabbitMQ nodes, ensuring that queues can still run when a node breaks down.
Quorum queues can be used in scenarios where queues exist for a long time and there are high requirements on queue fault tolerance and data security and low requirements on latency and queue features. Quorum queues are not recommended if a large number of messages may be stacked, because write significantly increases disk usage.
Messages in quorum queues are preferentially stored in the memory. You are advised to limit the queue length and memory usage of quorum queues. When the number of stacked messages exceeds the threshold, the messages are written to the disk to avoid high memory watermark.
For more information about quorum queues, see Quorum Queues.
Available only for RabbitMQ 3.8.35.
Comparing Quorum Queues and Mirrored Queues
Quorum queues are introduced in RabbitMQ 3.8 to address the technical limitations of mirrored queues. Quorum queues have similar functions as mirrored queues and provide high-availability queues for RabbitMQ.
Mirrored queues are slow at replicating messages.
- A mirrored queue has a queue leader and many mirrors. When a producer sends a message to the queue leader, the leader replicates the message to the mirrors, and sends back confirmation to the producer only after all mirrors have saved the message.
- If a node in a RabbitMQ cluster goes offline due to a fault, all data in the mirrors stored on the node will be lost after the fault is rectified and the node goes online again. In this case, O&M personnel need to determine whether to replicate data from the queue leader to the mirrors. If they choose not to replicate data, messages may be lost. If they choose to replicate data, the queue is blocked during replication and no operation can be performed on the queue. When a large number of messages are stacked, the queue will be unavailable for several minutes, hours, or even longer.
Quorum queues can solve these problems.
- Quorum queues are based on a variant of the Raft consensus algorithm. They deliver a higher message throughput. A quorum queue has a primary replica (queue leader) and many followers. When a producer sends a message to the leader, the leader replicates the message to the followers, and sends back confirmation to the producer only after half of the followers have saved the message. This means that a small number of slow followers do not affect the performance of the entire queue. Similarly, the election of the leader requires the consent of more than half of the followers, which prevents the queue from having two leaders in the event of network partitioning. Therefore, quorum queues attach more importance to consistency than availability.
- After a node in a RabbitMQ cluster goes online after recovering from a fault, the data stored on the node will not be lost. The queue leader directly replicates messages from the position where the followers were interrupted. The replication process is non-blocking, and the entire queue is not affected by the addition of new followers.
Compared with mirrored queues, quorum queues have fewer features, as shown in Table 1. Quorum queues consume more memory and disk space.
Feature |
Mirrored Queues |
Quorum Queues |
Non-durable queues |
Supported |
Not supported |
Exclusive queues |
Supported |
Not supported |
Message persistence |
Per message |
Always |
Queue rebalancing |
Automatic |
Manual |
Message TTL |
Supported |
Not supported |
Queue TTL |
Supported |
Supported |
Queue length limit |
Supported |
Supported (except x-overflow: reject-publish-dlx) |
Lazy queues |
Supported |
Supported after the queue length is limited |
Message priority |
Supported |
Not supported |
Consumption priority |
Supported |
Supported |
Dead letter exchanges |
Supported |
Supported |
Dynamic policy |
Supported |
Supported |
Poison message (let consumers consume infinitely) handling |
Not supported |
Supported |
Global QoS prefetch |
Supported |
Not supported |
Configuring Quorum Queues
When declaring a queue, set the x-queue-type queue argument to quorum. This argument can be set only during queue declaration and cannot be set by using a policy.
The default replication factor of a quorum queue is five.
- The following example shows how to configure a quorum queue on a Java client.
ConnectionFactory factory = newConnectionFactory(); factory.setRequestedHeartbeat(30); factory.setHost(HOST); factory.setPort(PORT); factory.setUsername(USERNAME); factory.setPassword(PASSWORD); finalConnection connection = factory.newConnection(); finalChannel channel = connection.createChannel(); // Create the queue parameter map. Map<String, Object> arguments = newHashMap<>(); arguments.put("x-queue-type", "quorum"); // Declare the quorum queue. channel.queueDeclare("test-quorum-queue", true, false, false, arguments);
- The following example shows how to configure a quorum queue on the RabbitMQ management UI.
Figure 1 Configuring a quorum queue
After the configuration is complete, check whether the queue type is quorum on the Queues page, as shown in Figure 2. In the Node column, +2 indicates that the queue has two replicas. Blue indicates that the two replicas have been synchronized. Red indicates that some messages have not been replicated.
On the Queues page, click the name of the desired queue. Check the node where the leader of this quorum queue resides and the node where active followers reside.
Figure 3 Queue details page
Configuring the Quorum Queue Length
You can configure a policy or queue attributes to limit the length of a quorum queue and the length that can be stored in the memory.
- x-max-length: maximum number of messages in the quorum queue. If this limit is exceeded, excess messages will be discarded or sent to the dead letter exchange.
- x-max-length-bytes: maximum size (in bytes) of messages in the quorum queue. If this limit is exceeded, excess messages will be discarded or sent to the dead letter exchange.
- x-max-in-memory-length: maximum number of messages of the quorum queue that can be stored in memory.
- x-max-in-memory-bytes: maximum size (in bytes) of messages of the quorum queue that can be stored in memory.
The following describes how to limit the length of a quorum queue stored in the memory by configuring a policy or the queue attribute.
- By using a policy (recommended)
- By setting the queue parameter
