Enabling RabbitMQ Plug-ins
Updated on 2024-10-30 GMT+08:00
After creating a RabbitMQ instance, you can enable add-ons through plug-ins. The plug-ins are disabled by default when the instance is created.
RabbitMQ plug-ins can be used for testing and service migration. Do not use them for production. Reliability issues caused from using plug-ins are not within commitments on SLAs. For details, see Service Overview > Notes and Constraints.
Table 1 lists plug-ins supported by RabbitMQ. The ports of the plug-ins cannot be changed.
Table 1 Plug-ins
Name
Function
Port
rabbitmq_amqp1_0
Support for AMQP 1.0
rabbitmq_delayed_message_exchange
Delayed messages
There may be an error of about 1%. The actual delivery time may be earlier or later than the scheduled delivery time.
rabbitmq_federation
Federation
rabbitmq_sharding
Sharding
rabbitmq_shovel
Message moving
rabbitmq_tracing
Message tracing
rabbitmq_mqtt
Support for MQTT over TCP
1883
rabbitmq_web_mqtt
Support for MQTT over WebSocket
15675
rabbitmq_stomp
Support for STOMP over TCP
61613
rabbitmq_web_stomp
Support for STOMP over WebSocket
15674
rabbitmq_consistent_hash_exchange
Support for x-consistent-hash. x-consistent-hash exchanges can be created after this plugin is enabled.
  • When plug-ins are enabled, the instance will not be restarted. However, enabling plug-ins rabbitmq_mqtt, rabbitmq_web_mqtt, rabbitmq_stomp, and rabbitmq_web_stomp will restart Keepalived and disconnect the instance. After the instance is disconnected, it may be automatically reconnected depending on the service logic.
  • The rabbitmq_shovel, rabbitmq_federation, and rabbitmq_tracing plug-ins can be enabled only for specific instances. For details, see Table 2.
    Table 2 Instances for which plug-ins can be enabled
    Instance
    rabbitmq_shovel
    rabbitmq_federation
    rabbitmq_tracing
    Single-node instances with SSL disabled
    Supported
    Supported
    Supported
    Single-node instances with SSL enabled
    Not supported
    Not supported
    Not supported
    Cluster instances with SSL disabled
    Not supported
    Supported
    Supported
    Cluster instances with SSL enabled
    Not supported
    Not supported
    Not supported
  1. Log in to the console.
  2. In the upper left corner, click and select a region.
    Select the region where your RabbitMQ instance is.
  3. Click and choose Application > Distributed Message Service for RabbitMQ to open the console of DMS for RabbitMQ.
  4. Click the desired instance to view its details.
  5. On the Plug-ins tab page, click Enable next to the desired plug-in.
    Confirm that you want to enable the plug-in and wait for it to be enabled successfully.
