- What's New
- Function Overview
- Product Bulletin
Service Overview
- Infographics
- What Is DMS for RabbitMQ?
- Product Advantages
- Application Scenarios
- Specifications
- Comparing RabbitMQ, Kafka, and RocketMQ
- Comparing RabbitMQ AMQP-0-9-1 with Open-Source RabbitMQ
- Comparing RabbitMQ Versions
- Related Services
- Security
- Notes and Constraints
- Basic Concepts
- Exchanges
- Permissions Management
- Billing
- Getting Started
User Guide
- Process of Using RabbitMQ
- Buying a RabbitMQ Instance
- Configuring Virtual Hosts
- Accessing a RabbitMQ Instance
- Managing Messages
- Advanced Features
Managing Instances
- Viewing and Modifying Basic Information of a RabbitMQ Instance
- Viewing RabbitMQ Client Connection Addresses
- Managing RabbitMQ Instance Tags
- Configuring RabbitMQ Recycling Policies
- Resetting the RabbitMQ Instance Password
- Enabling RabbitMQ Plug-ins
- Exporting the RabbitMQ Instance List
- Deleting a RabbitMQ Instance
- Logging In to RabbitMQ Management UI
- Modifying RabbitMQ Instance Specifications
- Migrating RabbitMQ Services
- Testing Instance Performance
- Applying for Increasing RabbitMQ Quotas
- Viewing Metrics and Configuring Alarms
- Viewing RabbitMQ Audit Logs
Best Practices
- RabbitMQ Best Practices
- Automatic Recovery of a RabbitMQ Client from Network Exceptions
- Automatic Consumer Reconnection After a RabbitMQ Node Restart
- Improving RabbitMQ Performance
- Configuring Queue Load Balancing
- Deduplicating Messages Through Message Idempotence
- Suggestions on Using DMS for RabbitMQ Securely
- Developer Guide
API Reference
- Before You Start
- API Overview
- Calling APIs
- Getting Started
- APIs V2 (Recommended)
- Out-of-Date APIs
- Appendix
- Change History
- SDK Reference
Instances
- What RabbitMQ Version Does DMS for RabbitMQ Use?
- What SSL Version Does DMS for RabbitMQ Use?
- Why Can't I View the Subnet and Security Group Information During Instance Creation?
- How Are Requests Evenly Distributed to Each VM of a Cluster RabbitMQ Instance?
- Do Queues Inside a Cluster RabbitMQ Instance Have Any Redundancy Backup?
- Does DMS for RabbitMQ Support Data Persistence? How Do I Perform Scheduled Data Backups?
- How Do I Obtain the Certificate After SSL Has Been Enabled?
- Can I Change the SSL Setting of a RabbitMQ Instance?
- Can RabbitMQ Instances Be Scaled Up?
- Does RabbitMQ Support Two-Way Authentication?
- Does DMS for RabbitMQ Support CPU and Memory Upgrades?
- How Do I Disable the RabbitMQ Management UI?
- Can I Change the AZ for an Instance?
- How Do I Obtain the Region ID?
- Why Can't I Select Two AZs?
- How to Change Single-node RabbitMQ Instances to Cluster Ones?
- Can I Change the VPC and Subnet After a RabbitMQ Instance Is Created?
Connections
- How Do I Configure a Security Group?
- Why Does a Client Fail to Connect to a RabbitMQ Instance?
- Does DMS for RabbitMQ Support Public Access?
- Does DMS for RabbitMQ Support Cross-Region Deployment?
- Do RabbitMQ Instances Support Cross-VPC Access?
- Do RabbitMQ Instances Support Cross-Subnet Access?
- What Should I Do If I Fail to Access a RabbitMQ Instance with SSL Encryption?
- Can I Access a RabbitMQ Instance Using DNAT?
- Why Can't I Open the Management Web UI?
- Can a Client Connect to Multiple Virtual Hosts of a RabbitMQ Instance?
- Why Does a RabbitMQ Cluster Have Only One Connection Address?
- Do RabbitMQ Instances Support the Ping Command?
- Messages
- Monitoring & Alarm
Instances
- Videos
More Documents
- Getting Started
- Managing Messages
- Advanced Features
Managing Instances
- Using the rabbitmq_tracing Plug-in
Instances
Connections
- Messages
Instances
- Change History
- API Reference (ME-Abu Dhabi Region)
- Preparing the Environment
- Buying an Instance
- Operating RabbitMQ Instances
- Quotas
- Monitoring
- Auditing
Instances
- What If One RabbitMQ VM Fails to Be Restarted When a Cluster RabbitMQ Instance Is Being Restarted?
- Does DMS for RabbitMQ Support MQTT?
- How Do I Clear Queue Data?
Connections
- Does DMS for RabbitMQ Support Cross-VPC Access?
- Does DMS for RabbitMQ Support Cross-Subnet Access?
- Plug-ins
- Messages
Instances
- Change History
- API Reference (Kuala Lumpur Region)
Configuring Queue Mirroring
In a RabbitMQ cluster, queues can be mirrored across multiple nodes. In the event of a node failure, services are still available because the mirrors will take over services.
This section describes how to configure queue mirroring policies for a virtual host on the RabbitMQ management UI. Queues meet the policies are mirrored queues.
Prerequisite
A cluster RabbitMQ instance has been created.
Configuring RabbitMQ Queue Mirroring
- Log in to the management UI of a RabbitMQ instance.
- Click the Admin tab.
Figure 1 Admin tab page
- (Optional) Perform this step only if you need to specify a virtual host. Otherwise, go to 4.
In the navigation tree on the right, choose Virtual Hosts, specify Name, and click Add virtual host to create a virtual host.Figure 2 Creating a virtual host
- In the navigation tree on the right, choose Policies and set policies for the virtual host.
Figure 3 Setting virtual host policies
Table 1 Policy elements Parameter
Virtual Host
Specify the virtual host. To set policies for a specific virtual host, select the virtual host created in 3 from the Virtual host drop-down list box. If no virtual host has been created, the default value / is used.
Name
The policy name, which can be customized.
Pattern
Regular expression that defines the pattern for matching queues.
Apply to
Object to which the policy applies.
Priority
A larger value indicates a higher priority.
Definition
Definition of the mirror, which consists of ha-sync-mode, ha-mode, and ha-params.
- ha-sync-mode: queue synchronization mode. Options: automatic and manual.
- automatic: Data is automatically synchronized from the master.
- manual: Data is manually synchronized from the master.
- ha-mode: queue mirroring mode. Options: all, exactly, and nodes.
- all: Mirror the queue across all nodes in the cluster.
- exactly: Mirror the queue to a specific number (determined through ha-params) of nodes in the cluster.
- nodes: Mirror the queue to specific nodes (determined through ha-params).
- ha-params: This parameter is used in the ha-mode mode.
- Click Add policy.
The following figure shows a successfully added policy.
Figure 4 Virtual host policy
