Logging In to RabbitMQ Management UI
RabbitMQ instances support an open-source cluster management tool. The management UI can be accessed at the RabbitMQ management address for instance configurations.
- Obtain the management address of an instance.
- In the upper left corner, click
and select a region.
Select the same region as your application service.
- Click
and choose Application > Distributed Message Service for RabbitMQ to open the console of DMS for RabbitMQ. - Click the name of the instance whose management address you want to obtain. On the Basic Information tab page, view the Mgmt. UI Address, and Username.
The username and password are customized when the RabbitMQ instance was created.
- Check whether the rules of the security group of the instance are correctly configured.
- In the Network section on the Basic Information tab page, click the name of the security group.
- Click the Inbound Rules tab to view the inbound rules of the security group.
- SSL disabled
- For intra-VPC access, inbound access through port 5672 must be allowed.
- For public access, inbound access through port 15672 must be allowed.
- SSL enabled
- For intra-VPC access, inbound access through port 5671 must be allowed.
- For public access, inbound access through port 15671 must be allowed.
- SSL disabled
- In the address box of the browser, enter the URL of the management UI.
- If public access is enabled for the RabbitMQ instance, you can use a browser to access the web page through the public network.
- If public access is not enabled for the RabbitMQ instance, you must purchase a Windows ECS that can connect to the RabbitMQ instance. Then, log in to the ECS and access the web page.
Figure 1 Logging in to the management UI
- Enter the username and password and click Login.
