Deleting a RabbitMQ Instance
Delete one or more RabbitMQ instances at a time on the DMS for RabbitMQ console.
Deleting a RabbitMQ instance will delete the data in the instance without any backup. Exercise caution when performing this operation.
Prerequisite
The instance must be in the Running, Faulty, or Creation failed state.
- Log in to the console.
- In the upper left corner, click
and select a region.
Select the region where your RabbitMQ instance is.
- Click
and choose Application > Distributed Message Service for RabbitMQ to open the console of DMS for RabbitMQ.
- Delete pay-per-use RabbitMQ instances in one of the following ways:
- Select one or more RabbitMQ instances and click Delete in the upper left corner.
- In the row containing the RabbitMQ instance to be deleted, choose More > Delete.
- Click the desired RabbitMQ instance to view its details. In the upper right corner, choose More > Delete.
RabbitMQ instances in the Creating, Changing, or Change failed state cannot be deleted.
- In the Delete Instance dialog box, enter DELETE and click OK to delete the RabbitMQ instance.
It takes 1 to 60 seconds to delete a RabbitMQ instance.
