Help Center/ Distributed Message Service for RabbitMQ/ User Guide (ME-Abu Dhabi Region)/ Managing Instances/ Viewing and Modifying Basic Information of a RabbitMQ Instance
Updated on 2024-10-30 GMT+08:00
This section describes how to view the details, and modify the basic information of a RabbitMQ instance on the console.
After creating a RabbitMQ instance, you can modify some configurations of it as required, including the instance name, description, and security group.
Prerequisite
You can modify basic information of a RabbitMQ instance when the instance is in the Running state.
Viewing RabbitMQ Instance Details
  1. Log in to the console.
  2. In the upper left corner, click and select a region.
    Select the region where your RabbitMQ instance is.
  3. Click and choose Application > Distributed Message Service for RabbitMQ to open the console of DMS for RabbitMQ.
  4. RabbitMQ instances can be queried by filters. Current filters include the tag, status, name, connection address, and ID. Only enterprise users can use enterprise projects for filtering. For RabbitMQ instance statuses, see Table 1.
    Table 1 RabbitMQ instance status description
    Status
    Creating
    The instance is being created.
    Creation failed
    The instance failed to be created.
    Running
    The instance is running properly.
    Only instances in the Running state can provide services.
    Faulty
    The instance is not running properly.
    Changing
    The instance specifications are being changed.
    Change failed
    The instance specifications failed to be changed.
  5. Click the name of the RabbitMQ instance and view the instance details.
    Table 2 describes the parameters for connecting to an instance. For details about other parameters, see the Basic Information tab page of the RabbitMQ instance on the console.
    Table 2 Connection parameters
    Instance Address (Private Network)
    Address for connecting to the instance when public access is disabled.
    Mgmt. UI Address
    Address for connecting to the instance management UI when public access is disabled.
    Public Access
    Whether public access has been enabled.
    Instance Address (Public Network)
    Address for connecting to the instance when public access is enabled.
    Mgmt. UI Address (Public Network)
    Address for connecting to the instance management UI when public access is enabled.
    Select the region where your RabbitMQ instance is in.
  4. Click a RabbitMQ instance name to go to the instance details page.
  5. Modify the following parameters if needed:
    Table 3 Modifiable RabbitMQ parameters
    How to Modify
    Result
    Instance Name
    Click , enter a new name, and click .
    Naming rules: 4–64 characters; starts with a letter; can contain only letters, digits, hyphens (-), and underscores (_).
    The modification result is displayed in the upper right corner of the page.
    Enterprise Project
    Click , select a new enterprise project from the drop-down list, and click .
    Only for enterprise users. Modifying this parameter does not restart the instance.
    Click , enter a new description, and click .
    0 to 1024 characters.
    Security Group
    Click , select a new security group from the drop-down list, and click .
    Public Access
    See Configuring RabbitMQ Public Access.
    You will be redirected to the Background Tasks page, which displays the modification progress and result.
