- What's New
- Function Overview
- Product Bulletin
Service Overview
- Infographics
- What Is DMS for RabbitMQ?
- Product Advantages
- Application Scenarios
- Specifications
- Comparing RabbitMQ, Kafka, and RocketMQ
- Comparing RabbitMQ AMQP-0-9-1 with Open-Source RabbitMQ
- Comparing RabbitMQ Versions
- Related Services
- Security
- Notes and Constraints
- Basic Concepts
- Exchanges
- Permissions Management
- Billing
- Getting Started
User Guide
- Process of Using RabbitMQ
- Buying a RabbitMQ Instance
- Configuring Virtual Hosts
- Accessing a RabbitMQ Instance
- Managing Messages
- Advanced Features
Managing Instances
- Viewing and Modifying Basic Information of a RabbitMQ Instance
- Viewing RabbitMQ Client Connection Addresses
- Managing RabbitMQ Instance Tags
- Configuring RabbitMQ Recycling Policies
- Resetting the RabbitMQ Instance Password
- Enabling RabbitMQ Plug-ins
- Exporting the RabbitMQ Instance List
- Deleting a RabbitMQ Instance
- Logging In to RabbitMQ Management UI
- Modifying RabbitMQ Instance Specifications
- Migrating RabbitMQ Services
- Testing Instance Performance
- Applying for Increasing RabbitMQ Quotas
- Viewing Metrics and Configuring Alarms
- Viewing RabbitMQ Audit Logs
Best Practices
- RabbitMQ Best Practices
- Automatic Recovery of a RabbitMQ Client from Network Exceptions
- Automatic Consumer Reconnection After a RabbitMQ Node Restart
- Improving RabbitMQ Performance
- Configuring Queue Load Balancing
- Deduplicating Messages Through Message Idempotence
- Suggestions on Using DMS for RabbitMQ Securely
- Developer Guide
API Reference
- Before You Start
- API Overview
- Calling APIs
- Getting Started
- APIs V2 (Recommended)
- Out-of-Date APIs
- Appendix
- Change History
- SDK Reference
Instances
- What RabbitMQ Version Does DMS for RabbitMQ Use?
- What SSL Version Does DMS for RabbitMQ Use?
- Why Can't I View the Subnet and Security Group Information During Instance Creation?
- How Are Requests Evenly Distributed to Each VM of a Cluster RabbitMQ Instance?
- Do Queues Inside a Cluster RabbitMQ Instance Have Any Redundancy Backup?
- Does DMS for RabbitMQ Support Data Persistence? How Do I Perform Scheduled Data Backups?
- How Do I Obtain the Certificate After SSL Has Been Enabled?
- Can I Change the SSL Setting of a RabbitMQ Instance?
- Can RabbitMQ Instances Be Scaled Up?
- Does RabbitMQ Support Two-Way Authentication?
- Does DMS for RabbitMQ Support CPU and Memory Upgrades?
- How Do I Disable the RabbitMQ Management UI?
- Can I Change the AZ for an Instance?
- How Do I Obtain the Region ID?
- Why Can't I Select Two AZs?
- How to Change Single-node RabbitMQ Instances to Cluster Ones?
- Can I Change the VPC and Subnet After a RabbitMQ Instance Is Created?
Connections
- How Do I Configure a Security Group?
- Why Does a Client Fail to Connect to a RabbitMQ Instance?
- Does DMS for RabbitMQ Support Public Access?
- Does DMS for RabbitMQ Support Cross-Region Deployment?
- Do RabbitMQ Instances Support Cross-VPC Access?
- Do RabbitMQ Instances Support Cross-Subnet Access?
- What Should I Do If I Fail to Access a RabbitMQ Instance with SSL Encryption?
- Can I Access a RabbitMQ Instance Using DNAT?
- Why Can't I Open the Management Web UI?
- Can a Client Connect to Multiple Virtual Hosts of a RabbitMQ Instance?
- Why Does a RabbitMQ Cluster Have Only One Connection Address?
- Do RabbitMQ Instances Support the Ping Command?
- Messages
- Monitoring & Alarm
Instances
- Videos
More Documents
- Getting Started
- Managing Messages
- Advanced Features
Managing Instances
- Using the rabbitmq_tracing Plug-in
Instances
Connections
- Messages
Instances
- Change History
- API Reference (ME-Abu Dhabi Region)
- Preparing the Environment
- Buying an Instance
- Operating RabbitMQ Instances
- Quotas
- Monitoring
- Auditing
Instances
- What If One RabbitMQ VM Fails to Be Restarted When a Cluster RabbitMQ Instance Is Being Restarted?
- Does DMS for RabbitMQ Support MQTT?
- How Do I Clear Queue Data?
Connections
- Does DMS for RabbitMQ Support Cross-VPC Access?
- Does DMS for RabbitMQ Support Cross-Subnet Access?
- Plug-ins
- Messages
Instances
- Change History
- API Reference (Kuala Lumpur Region)
Show all
Configuring RabbitMQ Alarms
This section describes the alarm rules of some metrics and how to configure the rules. In actual scenarios, you are advised to configure alarm rules for metrics by referring to the following alarm policies.
Metric |
Alarm Policy |
Description |
Solution |
Available Messages |
Alarm threshold: Raw data > Expected number of available messages Number of consecutive periods: 1 Alarm severity: Major |
If the number of available messages is too large, messages are accumulated. |
Unacked Messages |
Alarm threshold: Raw data > Expected number of unacknowledged messages Number of consecutive periods: 1 Alarm severity: Major |
If the number of unacknowledged messages is too large, messages may be accumulated. |
Connections |
Alarm threshold: Raw data > Expected number of connections Number of consecutive periods: 1 Alarm severity: Major |
A sharp increase in the number of connections may be a warning of a traffic increase. |
The services may be abnormal. Check whether other alarms exist. |
Channels |
Alarm threshold: Raw data > Expected number of channels Number of consecutive periods: 1 Alarm severity: Major |
A sharp increase in the number of channels may be a warning of a traffic increase. |
Erlang Processes |
Alarm threshold: Raw data > Expected number of processes Number of consecutive periods: 1 Alarm severity: Major |
A sharp increase in the number of processes may be a warning of a traffic increase. |
- Set the alarm threshold based on the service expectations. For example, if the expected usage is 35%, set the alarm threshold to 35%.
- The number of consecutive periods and alarm severity can be adjusted based on the service logic.
- Log in to the console.
- In the upper left corner, click
and select a region.
Select the region where your RabbitMQ instance is.
- Click
and choose Application > Distributed Message Service for RabbitMQ to open the console of DMS for RabbitMQ.
- View the instance metrics using either of the following methods:
- In the row containing the desired instance, click View Metric. On the Cloud Eye console, view the metrics of the instance, nodes, and queues. Metric data is reported to Cloud Eye every minute.
- Click the desired RabbitMQ instance to view its details. In the navigation pane, choose Monitoring. On the displayed page, view the metrics of the instance, nodes, and queues. Metric data is updated every minute.
- Hover the mouse pointer over a metric and click
to create an alarm rule for the metric.
- Specify the alarm rule details.
For more information about creating alarm rules, see Creating an Alarm Rule.
- Enter the alarm name and description.
- Specify the alarm policy and alarm severity.
For example, an alarm can be triggered and notifications can be sent once every day if the raw value of connections exceeds the preset value for three consecutive periods and no actions are taken to handle the exception.
- Set Alarm Notification configurations. If you enable Alarm Notification, set the validity period, notification object, and trigger condition.
- Click Create.
