Applying for Increasing RabbitMQ Quotas
What Is Quota?
A quota is a limit on the quantity or capacity of a certain type of service resources that you can use, for example, the maximum number of RabbitMQ instances that you can create.
If the current resource quota cannot meet your service requirements, you can apply for a higher quota.
How Do I View My Quota?
- Log in to the console.
- Click
in the upper left corner to select a region and a project. - Click
(the My Quota icon) in the upper right corner.
The Quotas page is displayed.
- On the Quotas page, view the used and total quotas of resources.
If a quota cannot meet your needs, apply for a higher quota by performing the following operations.
How Do I Increase My Quota?
The system does not support online quota adjustment. To increase a quota, contact customer service by calling the hotline or sending an email. We will process your request as soon as possible and will inform you of the processing progress by phone or email.
Before you contact customer service, prepare the following information:
- Account name, project name, and project ID
To obtain the preceding information, log in to the management console, click the username in the upper-right corner, and choose My Credentials from the drop-down list.
- Quota information, including:
- Service name
- Quota type
- Required quota
To increase a quota, contact the administrator.
