Help Center/ Distributed Message Service for RabbitMQ/ User Guide (ME-Abu Dhabi Region)/ Getting Started/ Getting Started with RabbitMQ for Message Production and Consumption
Updated on 2024-10-30 GMT+08:00
This section takes an example to get you started with DMS for RabbitMQ. The example creates a RabbitMQ instance with SSL disabled, and accesses it over a private network on a client within a VPC. As a result, messages can be produced and consumed.
Figure 1 Procedure for using DMS for RabbitMQ
  1. Step 1: Preparations
    A RabbitMQ instance runs in a Virtual Private Cloud (VPC). Before creating a RabbitMQ instance, ensure that a VPC is available.
  2. Step 2: Creating a RabbitMQ Instance
    You can select the specifications and quantity when creating a RocketMQ instance.
  3. Step 3: Accessing an Instance for Message Production and Consumption
    A client connects to the instance with SSL disabled using the demo provided by RabbitMQ.
  1. Grant RabbitMQ instance permissions.
    To achieve fine-grained management of your cloud resources, create Identity and Access Management (IAM) user groups and users and grant specified permissions to the users. For more information, see Creating an IAM User and Granting DMS for RabbitMQ Permissions.
  2. Create a VPC and subnet.
    Before creating a RabbitMQ instance, ensure that a VPC and a subnet are available. For details about how to create a VPC and subnet, see .
    NOTICE:
    The VPC must be created in the same region as the RabbitMQ instance.
  3. Create a security group and add security group rules.
    Before creating a RabbitMQ instance, ensure that a security group is available. For details about how to create a security group, see .
    To connect to RabbitMQ instances, add the security group rules described in Table 1. Other rules can be added based on site requirements.
    Table 1 Security group rules
    Direction
    Protocol
    Port
    Source address
    Inbound
    TCP
    5672
    0.0.0.0/0
    Accessing a RabbitMQ instance (SSL disabled)
    After a security group is created, it has a default inbound rule that allows communication among ECSs within the security group and a default outbound rule that allows all outbound traffic. If you access your RabbitMQ instance over a private network within a VPC, you do not need to add the rules described in Table 1.
  4. Construct a client for message production and consumption.
    This section uses a Linux elastic cloud server (ECS) as the client. Before creating a RabbitMQ instance, create an ECS with elastic IPs (EIPs), install JDK, and configure the environment variables.
    1. Log in to the console, click in the upper left corner, click Elastic Cloud Server under Computing, and then create an ECS.
      For details about how to create an ECS, see . If you already have an available ECS, skip this step.
    2. Log in to an ECS as user root.
    3. Install Java JDK and configure the environment variables JAVA_HOME and PATH.
      1. Download a JDK.
        Use Oracle JDK instead of ECS's default JDK (for example, OpenJDK), because ECS's default JDK may not be suitable. Obtain Oracle JDK 1.8.111 or later from Oracle's official website.
      2. Decompress the JDK.
        tar -zxvf jdk-8u321-linux-x64.tar.gz
        Change jdk-8u321-linux-x64.tar.gz to your JDK version.
      3. Open the .bash_profile file.
        vim ~/.bash_profile
      4. Add the following content:
        export JAVA_HOME=/opt/java/jdk1.8.0_321
        export PATH=$JAVA_HOME/bin:$PATH
        Change /opt/java/jdk1.8.0_321 to the path where you install JDK.
      5. Press Esc. Enter the following line and press Enter. Save the .bash_profile file and exit.
        :wq
      6. Run the following command to make the change take effect:
        source .bash_profile
      7. Check whether the JDK is installed.
        java -version
        If the following message is returned, the JDK is installed.
        java version "1.8.0_321"
  1. Log in to the RabbitMQ console, and click Buy Instance in the upper right corner.
  2. Set basic instance information. Table 2 lists the configuration details.
    Table 2 Basic instance settings
    Billing Mode
    Select Pay-per-use, which is a postpaid mode. You can pay after using the service, and will be billed for your usage duration. The fees are calculated in seconds and settled by hour.
    Region
    DMS for Kafka in different regions cannot communicate with each other over an intranet. Select a nearest location for low latency and fast access.
    Project
    Projects isolate compute, storage, and network resources across geographical regions. For each region, a preset project is available.
    Select UAE-Abu Dhabi (default).
    AZ
    An AZ is a physical region where resources use independent power supply and networks. AZs are physically isolated but interconnected through an internal network.
    Select AZ1.
    Instance Name
    You can customize a name that complies with the rules: 4–64 characters; starts with a letter; can contain only letters, digits, hyphens (-), and underscores (_).
    Enter "rabbitmq-test".
    Enterprise Project
    This parameter is for enterprise users. An enterprise project manages project resources in groups. Enterprise projects are logically isolated.
    Select default.
    Version
    RabbitMQ version.
    Select 3.8.35.
    Specifications
    Select Single-node, which indicates that a RabbitMQ broker will be deployed.
    CPU Architecture
    x86
    Retain the default value.
    Broker Flavor
    Select a broker flavor as required.
    Select rabbitmq.2u4g.single.
    Brokers
    Fixed and the default value is 1.
    Storage Space per Broker
    Select the disk type and specify the disk size as required.
    Total storage space = Storage space per broker × Broker quantity. The disk type cannot be changed once the instance is created.
    Select Ultra-high I/O and enter 100.
    Disk Encryption
    Skip it.
  3. Configure the instance network. For details, see Table 3.
    Table 3 Configuring instance network
    VPC
    The VPC and subnet cannot be changed once the instance is created.
    Select the VPC and subnet prepared in 2.
    Security Group
    Select the security group prepared in 3.
  4. Set the instance access mode . For details, see Table 4.
    Table 4 Configuring the instance access mode
    SSL
    Skip it.
    Username
    Enter the username used for accessing the instance.
    A username should contain 4 to 64 characters, start with a letter, and contain only letters, digits, hyphens (-), and underscores (_).
    Enter "test".
    Password
    Enter the password used for accessing the instance.
    A password must meet the following requirements:
    • Contains 8 to 32 characters.
    • Contains at least three types of the following characters: uppercase letters, lowercase letters, digits, and special characters `~! @#$ %^&*()-_=+\|[{}];:'",<.>? and spaces, and cannot start with a hyphen (-).
    • Cannot be the username spelled forwards or backwards.
  5. Skip Advanced Settings.
  6. Click Buy.
  7. Confirm the instance information and then submit the request.
  8. Return to the instance list and check whether the instance has been created.
    It takes 3 to 15 minutes to create an instance. During this period, the instance status is Creating.
    • If the instance is created successfully, its status changes to Running.
    • If the instance is in the Creation failed state, delete it and try purchasing another one. If the instance purchase fails again, contact customer service.
  9. After the instance is created, click its name to go to the instance details page.
  10. In the Connection area, view and record the connection address.
  1. Go to the root directory on the ECS and download the sample project code RabbitMQ-Tutorial.zip.
    wget https://dms-demo.obs.cn-north-1.myhuaweicloud.com/RabbitMQ-Tutorial.zip
    /root is the path for storing the sample project code. Change it to the actual path if needed.
  2. Run the following command to decompress RabbitMQ-Tutorial.zip:
    unzip RabbitMQ-Tutorial.zip
  3. Run the following command to navigate to the RabbitMQ-Tutorial directory, which contains the precompiled JAR file:
    cd RabbitMQ-Tutorial
  4. Produce messages using the sample project.
    java -cp .:rabbitmq-tutorial.jar Send ${host} ${port} ${user} ${password}
    Description:
    Sample message production:
    [root@ecs-test RabbitMQ-Tutorial]# java -cp .:rabbitmq-tutorial.jar Send 192.168.xx.40 5672 test Zxxxxxxs
     [x] Sent 'Hello World!'
  5. Consume messages using the sample project.
    java -cp .:rabbitmq-tutorial.jar Recv ${host} ${port} ${user} ${password}
    Description:
    Sample message consumption:
    [root@ecs-test RabbitMQ-Tutorial]# java -cp .:rabbitmq-tutorial.jar Recv 192.168.xx.40 5672 test Zxxxxxxs
     [*] Waiting for messages. To exit press CTRL+C
     [x] Received 'Hello World!'
    Press Ctrl+C to cancel.
