Permissions Management
Updated on 2024-10-30 GMT+08:00
You can use Identity and Access Management (IAM) to manage DMS for RabbitMQ permissions and control access to your resources. IAM provides identity authentication, permissions management, and access control.
You can create IAM users for your employees, and assign permissions to these users on a principle of least privilege (PoLP) basis to control their access to specific resource types. For example, you can create IAM users for software developers and assign specific permissions to allow them to use DMS for RabbitMQ resources but prevent them from being able to delete resources or perform any high-risk operations.
If your account does not require individual IAM users for permissions management, skip this section.
IAM is free of charge. You pay only for the resources you use. For more information, see IAM Service Overview.
DMS for RabbitMQ Permissions
By default, new IAM users do not have any permissions assigned. To assign permissions to these new users, add them to one or more groups, and attach permissions policies or roles to these groups.
DMS for RabbitMQ is a project-level service deployed and accessed in specific physical regions. When assigning DMS for RabbitMQ permissions to a user group, specify region-specific projects where the permissions will take effect. If you select All projects, the permissions will be granted for all region-specific projects. When accessing DMS for RabbitMQ, the users need to switch to a region where they have been authorized to use this service.
You can grant permissions by using roles and policies.
  • Roles: A type of coarse-grained authorization mechanism that provides only a limited number of service-level roles. When using roles to grant permissions, you also need to assign dependency roles. However, roles are not an ideal choice for fine-grained authorization and secure access control.
  • Policies: A fine-grained authorization strategy that defines permissions required to perform operations on specific cloud resources under certain conditions. This mechanism allows for more flexible policy-based authorization for securer access control. For example, you can grant DMS for RabbitMQ users only the permissions for managing a certain type of DMS for RabbitMQ instances. Most policies define permissions based on APIs. For the API actions supported by DMS for RabbitMQ, see Permissions Policies and Supported Actions.
Permissions policies of DMS for RabbitMQ are based on DMS. Therefore, when assigning permissions, select DMS permissions policies.
Table 1 lists all the system-defined roles and policies supported by DMS for RabbitMQ.
Table 1 System-defined roles and policies supported by DMS for RabbitMQ
Role/Policy Name
Type
Dependency
DMS FullAccess
Administrator permissions for DMS. Users granted these permissions can perform all operations on DMS.
System-defined policy
None
DMS UserAccess
Common user permissions for DMS, excluding permissions for creating, modifying, deleting, and scaling up instances.
None
DMS ReadOnlyAccess
Read-only permissions for DMS. Users granted these permissions can only view DMS data.
None
DMS VPCAccess
VPC operation permissions to assign to DMS agencies.
System-defined policies
None
DMS KMSAccess
KMS operation permissions to assign to DMS agencies.
None
DMS Administrator
System-defined role
This role depends on the Tenant Guest and VPC Administrator roles.
Table 2 lists the common operations supported by each DMS for RabbitMQ system policy or role. Select the policies or roles as required.
Table 2 Common operations supported by system-defined policies
Operation
DMS FullAccess
DMS UserAccess
DMS ReadOnlyAccess
DMS VPCAccess
DMS KMSAccess
Creating instances
Modifying instances
Deleting instances
Modifying instance specifications
Querying instance information
