Help Center/ Object Storage Service/ User Guide (ME-Abu Dhabi Region)/ FAQs/ OBS Basics/ How Much Data Can I Store in OBS?
Updated on 2022-05-17 GMT+08:00
There are no restrictions on the total capacity or number of objects or files that can be stored by the OBS system or in any single bucket. However, there are limitations on what you can upload to your bucket at a time.
- OBS Console supports batch upload. A maximum of 100 files can be uploaded in a batch with the total size of no more than 5 GB. If you upload only one file in the batch upload mode, the maximum size of the file is 5 GB.
- If you use OBS Browser+ or an API, you can upload a single object of up to 48.8 TB.
Parent topic: OBS Basics
0
3
4
5
6
7
8
9
10
Very dissatisfiedVery satisfied
