Manager Basic Principles
Overview
Manager is the O&M management system of MRS and provides unified cluster management capabilities for services deployed in clusters.
Manager provides functions such as performance monitoring, alarms, user management, permission management, auditing, service management, health check, and log collection.
Architecture
Figure 1 shows the overall logical architecture of FusionInsight Manager.
Manager consists of OMS and OMA.
- OMS: serves as management node in the O&M system. There are two OMS nodes deployed in active/standby mode.
 - OMA: managed node in the O&M system. Generally, there are multiple OMA nodes.
Figure 1 describes the modules shown in Table 1.
        Module  |
        Description  |
        Web Service  |
        A web service deployed under Tomcat, providing HTTPS API of Manager. It is used to access Manager through the web browser. In addition, it provides the northbound access capability based on the Syslog and SNMP protocols.  |
        OMS  |
        Management node of the O&M system. Generally, there are two OMS nodes that work in active/standby mode.  |
        OMA  |
        Managed node in the O&M system. Generally, there are multiple OMA nodes.  |
        Controller  |
        The control center of Manager. It can converge information from all nodes in the cluster and display it to MRS cluster administrators, as well as receive from MRS cluster administrators, and synchronize information to all nodes in the cluster according to the operation instruction range. Control process of Manager. It implements various management actions:
        Node Agent  |
        Node Agent exists on each cluster node and is an enabler of Manager on a single node.
 Node Agent sends heartbeat messages to Controller at an interval of 3 seconds. The interval cannot be configured.  |
        IAM  |
        Records audit logs. Each non-query operation on the Manager UI has a related audit log.  |
        PMS  |
        The performance monitoring module. It collects the performance monitoring data on each OMA and provides the query function.  |
        CEP  |
        Convergence function module. For example, the used disk space of all OMAs is collected as a performance indicator.  |
        FMS  |
        Alarm module. It collects and queries alarms on each OMA.  |
        OMM Agent  |
        Agent for performance monitoring and alarm reporting on the OMA. It collects performance monitoring data and alarm data on Agent Node.  |
        CAS  |
        Unified authentication center. When a user logs in to the web service, CAS authenticates the login. The browser automatically redirects the user to the CAS through URLs.  |
        AOS  |
        Permission management module. It manages the permissions of users and user groups.  |
        ACS  |
        User and user group management module. It manages users and user groups to which users belong.  |
        Kerberos  |
        LDAP is deployed in OMS and a cluster, respectively.
        Ldap  |
        Database  |
        Manager database used to store logs and alarms.  |
        HA  |
        HA management module that manages the active and standby OMSs.  |
        NTP Server NTP Client  |
        It synchronizes the system clock of each node in the cluster.  |
