Manually Scale Out/In a Cluster
Updated on 2022-12-08 GMT+08:00
The processing capability of a big data cluster can be horizontally expanded by adding nodes. If the cluster scale does not meet service requirements, you can manually scale out or scale in the cluster. MRS intelligently selects the node with the least load or the minimum amount of data to be migrated for scale-in. The node to be scaled in will not receive new tasks, and continues to execute the existing tasks. At the same time, MRS copies its data to other nodes and the node is decommissioned. If the tasks on the node cannot be completed after a long time, MRS migrates the tasks to other nodes, minimizing the impact on cluster services.
Scaling Out a Cluster
Currently, you can add Core or Task nodes to scale out a cluster to handle peak service loads. The capacity expansion of an MRS cluster node does not affect the services of the existing cluster.
Scaling In a Cluster
You can reduce the number of Core or Task nodes to scale in a cluster so that MRS delivers better storage and computing capabilities at lower O&M costs based on service requirements. After you scale in an MRS cluster, MRS automatically selects nodes that can be scaled in based on the type of services installed on the nodes.
During the scale-in of Core nodes, data on the original nodes is migrated. If the data location is cached, the client automatically updates the location information, which may affect the latency. Node scale-in may affect the response duration of the first access to some HBase on HDFS data. You can restart HBase or disable or enable related tables to avoid this problem.
Task nodes do not store cluster data. They are compute nodes and do not involve migration of data on the nodes.
