Related Services
Relationships with Other Services
Service |
Relationships |
Virtual Private Cloud (VPC) |
MRS clusters are created in the subnets of a VPC. VPCs provide a secure, isolated, and logical network environment for your MRS clusters. |
Object Storage Service (OBS) |
OBS stores the following user data:
In MRS clusters, HDFS, Hive, MapReduce, Yarn, Spark, Flume, and Loader can import or export data from OBS. MRS uses the parallel file system of OBS to provide services. |
Elastic Cloud Server (ECS) |
MRS uses elastic cloud servers (ECSs) as cluster nodes. |
Relational Database Service (RDS) |
RDS stores MRS system running data, including MRS cluster metadata. |
Identity and Access Management (IAM) |
IAM provides authentication for MRS. |
Simple Message Notification (SMN) |
MRS uses SMN to provide one-to-multiple message subscription and notification over a variety of protocols. |
Cloud Trace Service (CTS) |
CTS provides you with operation records of MRS resource operation requests and request results for querying, auditing, and backtracking. |
Operation |
Resource Type |
Trace Name |
Creating a cluster |
cluster_mrs |
createCluster |
Deleting a cluster |
cluster_mrs |
deleteCluster |
Expanding a cluster |
cluster_mrs |
scaleOutCluster |
Shrinking a cluster |
cluster_mrs |
scaleInCluster |
After you enable CTS, the system starts recording operations on cloud resources. You can view operation records of the last 7 days on the CTS management console. For details, see Cloud Trace Service > Getting Started > Querying Real-Time Traces.
