On this page
Show all
Loader Basic Principles
Updated on 2022-12-08 GMT+08:00
Loader is developed based on the open source Sqoop component. It is used to exchange data and files between MRS and relational databases and file systems. Loader can import data from relational databases or file servers to the HDFS and HBase components, or export data from HDFS and HBase to relational databases or file servers.
A Loader model consists of Loader Client and Loader Server, as shown in Figure 1.
Figure 1 Loader model
Table 1 describes the functions of each module shown in the preceding figure.
Table 1 Components of the Loader model
Module
Loader Client
Loader client. It provides two interfaces: web UI and CLI.
Loader Server
Loader server. It processes operation requests sent from the client, manages connectors and metadata, submits MapReduce jobs, and monitors MapReduce job status.
REST API
It provides a Representational State Transfer (RESTful) APIs (HTTP + JSON) to process the operation requests sent from the client.
Job Scheduler
Simple job scheduler. It periodically executes Loader jobs.
Transform Engine
Data transformation engine. It supports field combination, string cutting, and string reverse.
Execution Engine
Loader job execution engine. It executes Loader jobs in MapReduce manner.
Submission Engine
Loader job submission engine. It submits Loader jobs to MapReduce.
Job Manager
It manages Loader jobs, including creating, querying, updating, deleting, activating, deactivating, starting, and stopping jobs.
Metadata Repository
Metadata repository. It stores and manages data about Loader connectors, transformation procedures, and jobs.
HA Manager
It manages the active/standby status of Loader Server processes. The Loader Server has two nodes that are deployed in active/standby mode.
Loader imports or exports jobs in parallel using MapReduce jobs. Some job import or export may involve only the Map operations, while some may involve both Map and Reduce operations.
Loader implements fault tolerance using MapReduce. Jobs can be rescheduled upon a job execution failure.
  • Importing data to HBase
    When the Map operation is performed for MapReduce jobs, Loader obtains data from an external data source.
    When a Reduce operation is performed for a MapReduce job, Loader enables the same number of Reduce tasks based on the number of Regions. The Reduce tasks receive data from Map tasks, generate HFiles by Region, and store the HFiles in a temporary directory of HDFS.
    When a MapReduce job is submitted, Loader migrates HFiles from the temporary directory to the HBase directory.
  • Importing Data to HDFS
    When a Map operation is performed for a MapReduce job, Loader obtains data from an external data source and exports the data to a temporary directory (named export directory-ldtmp).
    When a MapReduce job is submitted, Loader migrates data from the temporary directory to the output directory.
  • Exporting data to a relational database
    When a Map operation is performed for a MapReduce job, Loader obtains data from HDFS or HBase and inserts the data to a temporary table (Staging Table) through the Java DataBase Connectivity (JDBC) API.
    When a MapReduce job is submitted, Loader migrates data from the temporary table to a formal table.
  • Exporting data to a file system
    When a Map operation is performed for a MapReduce job, Loader obtains data from HDFS or HBase and writes the data to a temporary directory of the file server.
    When a MapReduce job is submitted, Loader migrates data from the temporary directory to a formal directory.
For details about the Loader architecture and principles, see https://sqoop.apache.org/docs/1.99.3/index.html.
