On this page
Help Center/ MapReduce Service/ User Guide (ME-Abu Dhabi Region)/ FAQs/ Client Usage/ An Error Is Reported When the kinit Command Is Executed on a Client Node Outside an MRS Cluster
Updated on 2022-12-08 GMT+08:00
Symptom
After the client is installed on a node outside an MRS cluster and the kinit command is executed, the following error information is displayed:
-bash kinit Permission denied
The following error information is displayed when the java command is executed:
-bash: /xxx/java: Permission denied
After running the ll /Java installation path/JDK/jdk/bin/java command, it is found that the file execution permission is correct.
Fault Locating
Run the mount | column -t command to check the status of the mounted partition. It is found that the partition status of the mount point where the Java execution file is located is noexec. In the current environment, the data disk where the MRS client is installed is set to noexec, that is, binary file execution is prohibited. As a result, Java commands cannot be executed.
Solution
  1. Log in to the node where the MRS client is located as user root.
  2. Remove the configuration item noexec of the data disk where the MRS client is located from the /etc/fstab file.
  3. Run the umount command to detach the data disk, and then run the mount -a command to remount the data disk.
