Help Center/
      MapReduce Service/
        User Guide (ME-Abu Dhabi Region)/
        FAQs/
        Kerberos Usage/
      How Do I Access Spark in a Cluster with Kerberos Authentication Enabled?
        Updated on 2022-12-08 GMT+08:00
- Log in to the master node in the cluster as user root.
 - Run the following command to configure environment variables:
 - If the Kerberos authentication is enabled for the current cluster, run the following command to authenticate the user.
Example:
If the development user is a machine-machine user, run kinit -kt user.keytab sparkuser.
If the development user is a human-machine user, run kinit sparkuser.
 - Run the following command to connect to Spark Beeline:
 - Run commands on Spark Beeline. For example, create the table test in the obs://mrs-word001/table/ directory.
create table test(id int) location 'obs://mrs-word001/table/';
 - Run the following command to query all tables. If table test is displayed in the command output, OBS access is successful.
   show tables;Figure 1 Returned table name
     - Press Ctrl+C to exit Spark Beeline.
   Parent topic: Kerberos Usage
