Help Center/
      MapReduce Service/
        User Guide (ME-Abu Dhabi Region)/
        FAQs/
        Big Data Service Development/
      How Do I Connect to Spark Shell from MRS?
- Log in to the Master node in the cluster as user root.
 - Run the following command to configure environment variables:
 - If Kerberos authentication is enabled for the cluster, authenticate the user. If Kerberos authentication is disabled, skip this step.
Command: kinit MRS cluster user
Example:
- If the user is a machine-machine user, run kinit -kt user.keytab sparkuser.
 - If the user is a human-machine user, run kinit sparkuser.
 - Run the following command to connect to Spark shell:
   Parent topic: Big Data Service Development
