Help Center/
      MapReduce Service/
        User Guide (ME-Abu Dhabi Region)/
        FAQs/
        Metadata Management/
      Where Can I View Hive Metadata?
        Updated on 2022-12-08 GMT+08:00
- If Hive metadata is stored in GaussDB of an MRS cluster, log in to the master DBServer node of the cluster, switch to user omm, and run the gsql -p 20051 -U {USER} -W {PASSWD} -d hivemeta command to view the metadata.
 - If Hive metadata is stored in an external relational database, perform the following steps:
- On the cluster Dashboard page, click Manage on the right of Data Connection.
 - On the displayed page, obtain the value of Data Connection ID.
 - On the MRS console, click Data Connections.
 - In the data connection list, locate the data connection based on the data connection ID obtained in 2.
 - Click Edit in the Operation column of the data connection.
The RDS Instance and Database indicate the relational database in which the Hive metadata is stored.
   Parent topic: Metadata Management
