Help Center/
      MapReduce Service/
        User Guide (ME-Abu Dhabi Region)/
        FAQs/
        MRS Overview/
      What Are the Differences Between Hive Versions?
        Updated on 2022-12-08 GMT+08:00
Hive 3.1 has the following differences when compared with Hive 1.2:
- String cannot be converted to int.
 - The user-defined functions (UDFs) of the Date type are changed to Hive built-in UDFs.
 - Hive 3.1 does not provide the index function anymore.
 - Hive 3.1 uses the UTC time in time functions, while Hive 1.2 uses the local time zone.
 - The JDBC drivers in Hive 3.1 and Hive 1.2 are incompatible.
 - In Hive 3.1, column names in ORC files are case-sensitive and underscores-sensitive.
 - Hive 3.1 does not allow columns named time.
   Parent topic: MRS Overview
