Help Center/
MapReduce Service/
User Guide (ME-Abu Dhabi Region)/
Troubleshooting/
Using Yarn/
An Error Is Reported When a Queue Name Is Clicked on the Yarn Page
Updated on 2022-12-08 GMT+08:00
Symptom
When Yarn uses the Capacity scheduler, error 500 is reported after a user clicks a queue name on the native Yarn web UI.
Cause Analysis
Symbol ^ in the URL cannot be identified. As a result, the page access fails.
- Log in to Manager and choose Cluster > Services > Yarn > Configurations > All Configurations.
- Search for yarn.resourcemanager.webapp.pagination.enable in the search box.
- If the value is true (default), change it to false and save the configuration.
- On the Yarn page, click Instance, select all ResourceManager instances, click More, and select Instance Rolling Restart. Wait until the instances are started.
Parent topic: Using Yarn
