On this page
Help Center/ MapReduce Service/ User Guide (ME-Abu Dhabi Region)/ Troubleshooting/ Cluster Management/ OS Disk Space Is Insufficient Due to Oversized HBase Log Files
Updated on 2022-12-08 GMT+08:00
Issue
The space of the /var/log partition on the system disk is insufficient.
Symptom
The /var/log/Bigdata/hbase/*/hbase-omm-*.out log file is too large, causing insufficient space of the /var/log partition on the system disk.
Cause Analysis
During the long-term running of HBase, the OS periodically deletes the /tmp/.java_pid* files created by the JVM. The HBase memory monitoring uses the jinfo command, which depends on the /tmp/.java_pid* file. If the file does not exist, the jinfo command runs kill -3 to print the jstack information to the .out log file. As a result, the .out log file becomes oversize as time goes by.
On each node hosting the HBase instance, deploy a scheduled task to periodically clear the .out log file. For example, log in to the HBase instance node and run the crontab -e command to add a scheduled task to clear the .out log file at 00:00:00 every day.
crontab -e
00 00 * * * for file in `ls /var/log/Bigdata/hbase/*/hbase-omm-*.out`; do echo "" > $file; done
If large .out files are generated frequently, you can clear the files multiple times every day or adjust the automatic clearing policy of the OS.
