Using Presto
- During sql-standard-with-group Configuration, a Schema Fails to Be Created and the Error Message "Access Denied" Is Displayed
 - The Presto coordinator cannot be started properly.
 - An Error Is Reported When Presto Is Used to Query a Kudu Table
 - No Data is Found in the Hive Table Using Presto
   Parent topic: Troubleshooting
