Help Center/
MapReduce Service/
User Guide (ME-Abu Dhabi Region)/
Troubleshooting/
Using Kafka/
Configuring Logs for Shell Commands on the Client
Updated on 2022-12-08 GMT+08:00
Issue
How do I set the log level for shell commands on the client?
- Log in to the node where the Kafka client is installed as the client installation user.
- Switch to the Kafka client installation directory, for example, /opt/client.
cd /opt/client
- Run the following command to switch to the Kafka client configuration directory:
cd Kafka/kafka/config
- Open the tools-log4j.properties file, change WARN to INFO, and save the file.
cd /opt/client
- Run the following command to configure environment variables:
source bigdata_env
- Run the following command to perform user authentication (skip this step for a cluster in common mode):
kinit Component service user
- Run the following command to switch to the Kafka client installation directory:
cd Kafka/kafka/bin
- Run the following command to obtain the topic information. The log information can be viewed on the console.
kafka-topics.sh --list --zookeeper 10.5.144.2:2181/kafka
[2017-02-17 14:34:27,005] INFO JAAS File name: /opt/client/Kafka/./kafka/config/jaas.conf (org.I0Itec.zkclient.ZkClient) [2017-02-17 14:34:27,007] INFO Starting ZkClient event thread. (org.I0Itec.zkclient.ZkEventThread) [2017-02-17 14:34:27,013] INFO Client environment:zookeeper.version=V100R002C10, built on 05/12/2016 08:56 GMT (org.apache.zookeeper.ZooKeeper) [2017-02-17 14:34:27,013] INFO Client environment:host.name=10-10-144-2 (org.apache.zookeeper.ZooKeeper) [2017-02-17 14:34:27,013] INFO Client environment:java.version=1.8.0_72 (org.apache.zookeeper.ZooKeeper) [2017-02-17 14:34:27,013] INFO Client environment:java.vendor=Oracle Corporation (org.apache.zookeeper.ZooKeeper) [2017-02-17 14:34:27,013] INFO Client environment:java.home=/opt/client/JDK/jdk/jre (org.apache.zookeeper.ZooKeeper) Test __consumer_offsets counter test test2 test3 test4
Parent topic: Using Kafka
