Help Center/
      MapReduce Service/
        User Guide (ME-Abu Dhabi Region)/
        Troubleshooting/
        Using Hive/
      beeline Reports the "OutOfMemoryError" Error
        Updated on 2022-12-08 GMT+08:00
Symptom
When a large amount of data is queried on the Beeline client, the message "OutOFMemoryError: Java heap space" is displayed. The detailed error information is as follows:
org.apache.thrift.TException: Error in calling method FetchResults at org.apache.hive.jdbc.HiveConnection$SynchronizedHandler.invoke(HiveConnection.java:1514) at com.sun.proxy.$Proxy4.FetchResults(Unknown Source) at org.apache.hive.jdbc.HiveQueryResultSet.next(HiveQueryResultSet.java:358) at org.apache.hive.beeline.BufferedRows.<init>(BufferedRows.java:42) at org.apache.hive.beeline.BeeLine.print(BeeLine.java:1856) at org.apache.hive.beeline.Commands.execute(Commands.java:873) at org.apache.hive.beeline.Commands.sql(Commands.java:714) at org.apache.hive.beeline.BeeLine.dispatch(BeeLine.java:1035) at org.apache.hive.beeline.BeeLine.execute(BeeLine.java:821) at org.apache.hive.beeline.BeeLine.begin(BeeLine.java:778) at org.apache.hive.beeline.BeeLine.mainWithInputRedirection(BeeLine.java:486) at org.apache.hive.beeline.BeeLine.main(BeeLine.java:469) Caused by: java.lang.OutOfMemoryError: Java heap space at com.sun.crypto.provider.CipherCore.doFinal(CipherCore.java:959) at com.sun.crypto.provider.CipherCore.doFinal(CipherCore.java:824) at com.sun.crypto.provider.AESCipher.engineDoFinal(AESCipher.java:436) at javax.crypto.Cipher.doFinal(Cipher.java:2223) at sun.security.krb5.internal.crypto.dk.AesDkCrypto.decryptCTS(AesDkCrypto.java:414) at sun.security.krb5.internal.crypto.dk.AesDkCrypto.decryptRaw(AesDkCrypto.java:291) at sun.security.krb5.internal.crypto.Aes256.decryptRaw(Aes256.java:86) at sun.security.jgss.krb5.CipherHelper.aes256Decrypt(CipherHelper.java:1397) at sun.security.jgss.krb5.CipherHelper.decryptData(CipherHelper.java:576) at sun.security.jgss.krb5.WrapToken_v2.getData(WrapToken_v2.java:130) at sun.security.jgss.krb5.WrapToken_v2.getData(WrapToken_v2.java:105) at sun.security.jgss.krb5.Krb5Context.unwrap(Krb5Context.java:1058) at sun.security.jgss.GSSContextImpl.unwrap(GSSContextImpl.java:403) at com.sun.security.sasl.gsskerb.GssKrb5Base.unwrap(GssKrb5Base.java:77) at org.apache.thrift.transport.TSaslTransport$SaslParticipant.unwrap(TSaslTransport.java:559) at org.apache.thrift.transport.TSaslTransport.readFrame(TSaslTransport.java:462) at org.apache.thrift.transport.TSaslTransport.read(TSaslTransport.java:435) at org.apache.thrift.transport.TSaslClientTransport.read(TSaslClientTransport.java:37) at org.apache.thrift.transport.TTransport.xxx(TTransport.java:86) at org.apache.hadoop.hive.thrift.TFilterTransport.xxx(TFilterTransport.java:62) at org.apache.thrift.protocol.TBinaryProtocol.xxx(TBinaryProtocol.java:429) at org.apache.thrift.protocol.TBinaryProtocol.readI32(TBinaryProtocol.java:318) at org.apache.thrift.protocol.TBinaryProtocol.readMessageBegin(TBinaryProtocol.java:219) at org.apache.thrift.TServiceClient.receiveBase(TServiceClient.java:77) at org.apache.hive.service.cli.thrift.TCLIService$Client.recv_FetchResults(TCLIService.java:505) at org.apache.hive.service.cli.thrift.TCLIService$Client.FetchResults(TCLIService.java:492) at sun.reflect.GeneratedMethodAccessor2.invoke(Unknown Source) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.lang.reflect.Method.invoke(Method.java:498) at org.apache.hive.jdbc.HiveConnection$SynchronizedHandler.invoke(HiveConnection.java:1506) at com.sun.proxy.$Proxy4.FetchResults(Unknown Source) at org.apache.hive.jdbc.HiveQueryResultSet.next(HiveQueryResultSet.java:358) Error: Error retrieving next row (state=,code=0)
Cause Analysis
- The data volume is excessively large.
 - Users use the select * from table_name; statement for query in the whole table. There is a large amount of data in the table.
 - The default startup memory of Beeline is 128 MB. The returned result set is too large during query, overloading Beeline.
Solution
- Before running select count(*) from table_name;, check the amount of data to be queried and determine whether to display data of this magnitude in Beeline.
 - If a certain amount of data needs to be displayed, adjust the JVM parameter of the Hive client. Add export HIVE_OPTS=-Xmx1024M (change the value based on service requirements) to component_env in the /Hive directory of the Hive client. Run the source command to obtain the /bigdata_env directory on the client.
   Parent topic: Using Hive
