On this page
Help Center/ MapReduce Service/ User Guide (ME-Abu Dhabi Region)/ Troubleshooting/ Using Hive/ "Failed to execute session hooks: over max connections" Reported by Beeline
Updated on 2022-12-08 GMT+08:00
Symptom
The default maximum connections to HiveServer are 200. When the number of connections exceeds 200, Beeline reports error "Failed to execute session hooks: over max connections."
beeline> [root@172-27-16-38 c70client]# beeline
Connecting to jdbc:hive2://129.188.82.38:24002,129.188.82.36:24002,129.188.82.35:24002/;serviceDiscoveryMode=zooKeeper;zooKeeperNamespace=hiveserver2;sasl.qop=auth-conf;auth=KERBEROS;principal=hive/hadoop.hadoop.com@HADOOP.COM
Debug is  true storeKey false useTicketCache true useKeyTab false doNotPrompt false ticketCache is null isInitiator true KeyTab is null refreshKrb5Config is false principal is null tryFirstPass is false useFirstPass is false storePass is false clearPass is false
Acquire TGT from Cache
Principal is xxx@HADOOP.COM
Commit Succeeded
Error: Failed to execute session hooks: over max connections. (state=,code=0)
Beeline version 1.2.1 by Apache Hive
The HiveServer log (/var/log/Bigdata/hive/hiveserver/hive.log) shows that error "over max connections" is reported.
2018-05-03 04:31:56,728 | WARN  | HiveServer2-Handler-Pool: Thread-137 | Error opening session:  | org.apache.hive.service.cli.thrift.ThriftCLIService.OpenSession(ThriftCLIService.java:542)
org.apache.hive.service.cli.HiveSQLException: Failed to execute session hooks: over max connections.
	at org.apache.hive.service.cli.session.SessionManager.openSession(SessionManager.java:322)
	at org.apache.hive.service.cli.CLIService.openSessionWithImpersonation(CLIService.java:189)
	at org.apache.hive.service.cli.thrift.ThriftCLIService.getSessionHandle(ThriftCLIService.java:663)
	at org.apache.hive.service.cli.thrift.ThriftCLIService.OpenSession(ThriftCLIService.java:527)
	at org.apache.hive.service.cli.thrift.TCLIService$Processor$OpenSession.getResult(TCLIService.java:1257)
	at org.apache.hive.service.cli.thrift.TCLIService$Processor$OpenSession.getResult(TCLIService.java:1242)
	at org.apache.thrift.ProcessFunction.process(ProcessFunction.java:39)
	at org.apache.thrift.TBaseProcessor.process(TBaseProcessor.java:39)
	at org.apache.hadoop.hive.thrift.HadoopThriftAuthBridge$Server$TUGIAssumingProcessor.process(HadoopThriftAuthBridge.java:710)
	at org.apache.thrift.server.TThreadPoolServer$WorkerProcess.run(TThreadPoolServer.java:286)
	at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
	at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
	at java.lang.Thread.run(Thread.java:745)
Caused by: org.apache.hive.service.cli.HiveSQLException: over max connections.
	at org.apache.hadoop.hive.transporthook.SessionControllerTsaslTransportHook.checkTotalSessionNumber(SessionControllerTsaslTransportHook.java:208)
	at org.apache.hadoop.hive.transporthook.SessionControllerTsaslTransportHook.postOpen(SessionControllerTsaslTransportHook.java:163)
	at org.apache.hadoop.hive.transporthook.SessionControllerTsaslTransportHook.run(SessionControllerTsaslTransportHook.java:134)
	at org.apache.hive.service.cli.session.SessionManager.executeSessionHooks(SessionManager.java:432)
	at org.apache.hive.service.cli.session.SessionManager.openSession(SessionManager.java:314)
	... 12 more
Cause Analysis
Heavy service traffic causes the number of connections to one HiveServer node to exceed 200, and the maximum number of connections to HiveServer needs to be increased.
Solution
  1. Search for hive.server.session.control.maxconnections and set it to a proper value not greater than 1000.
  2. Save the configuration and restart the affected services or instances.
