On this page
Help Center/ MapReduce Service/ User Guide (ME-Abu Dhabi Region)/ Troubleshooting/ Using Hive/ MetaStore Exception Occurs When the Number of DBService Connections Exceeds the Upper Limit
Updated on 2022-12-08 GMT+08:00
Symptom
By default, the maximum number of connections to DBService is 300. If the number of connections is greater than 300 due to heavy traffic, an exception occurs in MetaStore and error "slots are reserved for non-replication superuser connections" is reported.
2018-04-26 14:58:55,657 | ERROR | BoneCP-pool-watch-thread | Failed to acquire connection to jdbc:postgresql://10.*.*.*:20051/hivemeta?socketTimeout=60. Sleeping for 1000 ms. Attempts left: 9 | com.jolbox.bonecp.BoneCP.obtainInternalConnection(BoneCP.java:292)
org.postgresql.util.PSQLException: FATAL: remaining connection slots are reserved for non-replication superuser connections
	at org.postgresql.core.v3.ConnectionFactoryImpl.readStartupMessages(ConnectionFactoryImpl.java:643)
	at org.postgresql.core.v3.ConnectionFactoryImpl.openConnectionImpl(ConnectionFactoryImpl.java:184)
	at org.postgresql.core.ConnectionFactory.openConnection(ConnectionFactory.java:64)
	at org.postgresql.jdbc2.AbstractJdbc2Connection.<init>(AbstractJdbc2Connection.java:124)
	at org.postgresql.jdbc3.AbstractJdbc3Connection.<init>(AbstractJdbc3Connection.java:28)
	at org.postgresql.jdbc3g.AbstractJdbc3gConnection.<init>(AbstractJdbc3gConnection.java:20)
	at org.postgresql.jdbc4.AbstractJdbc4Connection.<init>(AbstractJdbc4Connection.java:30)
	at org.postgresql.jdbc4.Jdbc4Connection.<init>(Jdbc4Connection.java:22)
	at org.postgresql.Driver.makeConnection(Driver.java:392)
	at org.postgresql.Driver.connect(Driver.java:266)
	at java.sql.DriverManager.getConnection(DriverManager.java:664)
	at java.sql.DriverManager.getConnection(DriverManager.java:208)
	at com.jolbox.bonecp.BoneCP.obtainRawInternalConnection(BoneCP.java:361)
	at com.jolbox.bonecp.BoneCP.obtainInternalConnection(BoneCP.java:269)
	at com.jolbox.bonecp.ConnectionHandle.<init>(ConnectionHandle.java:242)
	at com.jolbox.bonecp.PoolWatchThread.fillConnections(PoolWatchThread.java:115)
	at com.jolbox.bonecp.PoolWatchThread.run(PoolWatchThread.java:82)
	at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
	at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
	at java.lang.Thread.run(Thread.java:745)
Cause Analysis
Heavy service traffic causes more than 300 connections to DBService, and the maximum number of connections to DBService needs to be increased.
Solution
  1. Search for dbservice.database.max.connections and set it to a proper value not greater than 1000.
  2. Save the configuration and restart the affected services or instances.
  3. If the fault persists, check the service code for any connection leaks.
