On this page
Failed to Access ZooKeeper from the Client
Updated on 2022-12-08 GMT+08:00
Symptom
In clusters in security mode, when the HiveServer service is normal and SQL is executed by using the JDBC interface to connect to HiveServer, "The ZooKeeper client is AuthFailed" is reported.
14/05/19 10:52:00 WARN utils.HAClientUtilDummyWatcher: The ZooKeeper client is AuthFailed
 14/05/19 10:52:00 INFO utils.HiveHAClientUtil: Exception thrown while reading data from znode.The possible reason may be connectionless. This is recoverable. Retrying..
 14/05/19 10:52:16 WARN utils.HAClientUtilDummyWatcher: The ZooKeeper client is AuthFailed
 14/05/19 10:52:32 WARN utils.HAClientUtilDummyWatcher: The ZooKeeper client is AuthFailed
 14/05/19 10:52:32 ERROR st.BasicTestCase: Exception: Could not establish connection to active hiveserver
 java.sql.SQLException: Could not establish connection to active hiveserver
Or an error is reported stating "Unable to read HiveServer2 configs from ZooKeeper":
Exception in thread "main" java.sql.SQLException: org.apache.hive.jdbc.ZooKeeperHiveClientException: Unable to read HiveServer2 configs from ZooKeeper
at org.apache.hive.jdbc.HiveConnection.<init>(HiveConnection.java:144)
at org.apache.hive.jdbc.HiveDriver.connect(HiveDriver.java:105)
at java.sql.DriverManager.getConnection(DriverManager.java:664)
at java.sql.DriverManager.getConnection(DriverManager.java:247)
at JDBCExample.main(JDBCExample.java:82)
Caused by: org.apache.hive.jdbc.ZooKeeperHiveClientException: Unable to read HiveServer2 configs from ZooKeeper
at org.apache.hive.jdbc.ZooKeeperHiveClientHelper.configureConnParams(ZooKeeperHiveClientHelper.java:100)
at org.apache.hive.jdbc.Utils.configureConnParams(Utils.java:509)
at org.apache.hive.jdbc.Utils.parseURL(Utils.java:429)
at org.apache.hive.jdbc.HiveConnection.<init>(HiveConnection.java:142)
... 4 more
Caused by: org.apache.zookeeper.KeeperException$ConnectionLossException: KeeperErrorCode = ConnectionLoss for /hiveserver2
at org.apache.zookeeper.KeeperException.create(KeeperException.java:99)
at org.apache.zookeeper.KeeperException.create(KeeperException.java:51)
at org.apache.zookeeper.ZooKeeper.getChildren(ZooKeeper.java:2374)
at org.apache.curator.framework.imps.GetChildrenBuilderImpl$3.call(GetChildrenBuilderImpl.java:214)
at org.apache.curator.framework.imps.GetChildrenBuilderImpl$3.call(GetChildrenBuilderImpl.java:203)
at org.apache.curator.RetryLo, op.callWithRetry(RetryLoop.java:107)
at org.apache.curator.framework.imps.GetChildrenBuilderImpl.pathInForeground(GetChildrenBuilderImpl.java:200)
at org.apache.curator.framework.imps.GetChildrenBuilderImpl.forPath(GetChildrenBuilderImpl.java:191)
at org.apache.curator.framework.imps.GetChildrenBuilderImpl.forPath(GetChildrenBuilderImpl.java:38)
Cause Analysis
  • When the client connects to HiveServer, the HiveServer address is automatically obtained from ZooKeeper. If ZooKeeper connection authentication is abnormal, the HiveServer address cannot be obtained from ZooKeeper correctly.
  • During ZooKeeper connection authentication, krb5.conf, principal, keytab, and related information must be loaded to the client. Authentication failure causes are as follows:
    • The user.keytab path is incorrectly entered.
    • user.principal is incorrectly entered.
    • The cluster has switched the domain name. However, the old principal is used when the client combines the URL.
    • The client cannot pass Kerberos authentication due to firewall settings. Ports 21730 (TCP), 21731 (TCP/UDP), and 21732 (TCP/UDP) need to be opened for Kerberos.
Solution
  1. Ensure that the user can properly access the user.keytab file in related paths on the client node.
  2. Ensure that the user's user.principal corresponds to the specified keytab file.
    Run the klist -kt keytabpath/user.keytab command to check the file.
  3. If the cluster has switched the domain name, the principal field used in the URL must be the new domain name.
    For example, the default value is hive/hadoop.hadoop.com@HADOOP.COM. If the cluster has switched the domain name, the field must be changed accordingly. For example, if the domain name is abc.com, enter hive/hadoop.abc.com@ABC.COM.
  4. Ensure that authentication is normal and HiveServer can be connected.
    Run the following commands on the client:
    source Client installation directory/bigdata_env
    kinit username
    Run the beeline command on the client to ensure normal running.
