Safety Instructions on Using Kafka
Updated on 2022-12-08 GMT+08:00
Brief Introduction to API for Kafka
  • New Producer API
    Indicates the API defined in org.apache.kafka.clients.producer.KafkaProducer. When kafka-console-producer.sh is used, the API is used by default.
  • Old Producer API
    Indicates the API defined in kafka.producer.Producer. When kafka-console-producer.sh is used, the API is invoked to add --old-producer.
  • New Consumer API
    Indicates the API defined in org.apache.kafka.clients.consumer.KafkaConsumer. When kafka-console-consumer.sh is used, the API is invoked to add --new-consumer.
  • Old Consumer API
    Indicates the API defined in kafka.consumer.ConsumerConnector. When kafka-console-consumer.sh is used, the API is used by default.
New Producer API and new Consumer API are called new API in general in the document.
Protocol Description for Accessing Kafka
The protocols used to access Kafka are as follows: PLAINTEXT, SSL, SASL_PLAINTEXT, and SASL_SSL.
When Kafka service is started, the listeners using the PLAINTEXT and SASL_PLAINTEXT protocols are started. You can set ssl.mode.enable to true in Kafka service configuration to start listeners using SSL and SASL_SSL protocols.
The following table describes the four protocols:
Protocol Type
Supported API
Default Port
PLAINTEXT
Supports plaintext access without authentication.
New and old APIs
9092
SASL_PLAINTEXT
Supports plaintext access with Kerberos authentication.
New API
21007
SSL
Supports SSL-encrypted access without authentication.
New API
9093
SASL_SSL
Supports SSL-encrypted access with Kerberos authentication.
New API
21009
ACL Settings for Topic
Kafka supports secure access. Therefore, users can set the ACL for topics to control that different users access different topics. To view and set the permission information about a topic, run the kafka-acls.sh script on the Linux client.
  • Scenarios
    Assign Kafka users with specific permissions for related topics based on service requirements.
    The following table describes default Kafka user groups.
    User Group
    kafkaadmin
    Kafka administrator group. Users added to this group have the permissions to create, delete, authorize, as well as read from and write data to all topics.
    kafkasuperuser
    Users added to this group have permissions to read data from and write data to all topics.
    kafka
    Kafka common user group. If users in this group want to read data from and write data to a specific topic, the users in the kafkaadmin group must grant permissions to users in this group.
  • Prerequisites
    1. The system administrator has understood service requirements and prepared a Kafka administrator (belonging to the kafkaadmin group).
    2. The Kafka client has been installed.
  • Procedure
    1. Log in to the node where the Kafka client is installed as the client installation user.
    2. Switch to the Kafka client installation directory, for example, /opt/kafkaclient.
      cd /opt/kafkaclient
    3. Run the following command to configure environment variables:
      source bigdata_env
    4. Run the following command to perform user authentication (skip this step for a cluster in common mode):
      kinit Component service user
    5. Run the following command to switch to the Kafka client installation directory:
      cd Kafka/kafka/bin
    6. The following describes the commands commonly used for user authorization when kafka-acl.sh is used:
      • View the permission control list of a topic:
        ./kafka-acls.sh --authorizer-properties zookeeper.connect=<ZooKeeper cluster service IP:2181/kafka > --list --topic <Topic name>
      • Add the Producer permission for a user:
        ./kafka-acls.sh --authorizer-properties zookeeper.connect=<ZooKeeper cluster service IP:2181/kafka > --add --allow-principal User:<username> --producer --topic <Topic name>
      • Remove the Producer permission from a user:
        ./kafka-acls.sh --authorizer-properties zookeeper.connect=<ZooKeeper cluster service IP:2181/kafka > --remove --allow-principal User:<username> --producer --topic <Topic name>
      • Add the Consumer permission for a user:
        ./kafka-acls.sh --authorizer-properties zookeeper.connect=<ZooKeeper cluster service IP:2181/kafka > --add --allow-principal User:<username> --consumer --topic <Topic name> --group <consumer group name>
      • Remove the Consumer permission from a user:
        ./kafka-acls.sh --authorizer-properties zookeeper.connect=<ZooKeeper cluster service IP:2181/kafka > --remove --allow-principal User:<username> --consumer --topic <Topic name> --group <consumer group name>
Use of New and Old Kafka APIs in Different Scenarios
  • Scenario 1: accessing the topic with an ACL
    Used API
    User Group
    Client Parameter
    Server Parameter
    Access Port
    New API
    Users need to meet one of the following conditions:
    • In the administrator group
    • In the kafkaadmin group
    • In the kafkasuperuser group
    • In the kafka group and be authorized
    security.protocol=SASL_PLAINTEXT sasl.kerberos.service.name = kafka
    sasl.port (The default number is 21007.)
    security.protocol=SASL_SSL sasl.kerberos.service.name = kafka
    Set ssl.mode.enable to true.
    sasl-ssl.port (The default port number is 21009.)
    Old API
    N/A
    N/A
    N/A
    N/A
  • Scenario 2: accessing the topic without an ACL
    Used API
    User Group
    Client Parameter
    Server Parameter
    Access Port
    New API
    Users are in the kafka group.
    Set allow.everyone.if.no.acl.found to true.
    security.protocol=SASL_SSLsasl.kerberos.service.name = kafka
    Set ssl-enable to true.
    security.protocol=PLAINTEXT
    port (The default number is 21005.)
    security.protocol=SSL
    ssl.port (The default number is 21008.)
    Old Producer
    Old Consumer
    ZooKeeper service port: clientPort (The default number is 24002.)
