Failed to Set an ACL for a Kafka Topic, and "NoAuthException" Is Displayed
Symptom
When running the following command on the Kafka client to set the ACL for a topic, it is found that the topic ACL cannot be set.
kafka-acls.sh --authorizer-properties zookeeper.connect=10.5.144.2:2181/kafka --topic topic_acl --producer --add --allow-principal User:test_acl
The error message "NoAuthException: KeeperErrorCode = NoAuth for /kafka-acl-changes/acl_changes_0000000002" is displayed.
Details are as follows:
Error while executing ACL command: org.apache.zookeeper.KeeperException$NoAuthException: KeeperErrorCode = NoAuth for /kafka-acl-changes/acl_changes_0000000002 org.I0Itec.zkclient.exception.ZkException: org.apache.zookeeper.KeeperException$NoAuthException: KeeperErrorCode = NoAuth for /kafka-acl-changes/acl_changes_0000000002 at org.I0Itec.zkclient.exception.ZkException.create(ZkException.java:68) at org.I0Itec.zkclient.ZkClient.retryUntilConnected(ZkClient.java:995) at org.I0Itec.zkclient.ZkClient.delete(ZkClient.java:1038) at kafka.utils.ZkUtils.deletePath(ZkUtils.scala:499) at kafka.common.ZkNodeChangeNotificationListener$$anonfun$purgeObsoleteNotifications$1.apply(ZkNodeChangeNotificationListener.scala:118) at kafka.common.ZkNodeChangeNotificationListener$$anonfun$purgeObsoleteNotifications$1.apply(ZkNodeChangeNotificationListener.scala:112) at scala.collection.mutable.ResizableArray$class.foreach(ResizableArray.scala:59) at scala.collection.mutable.ArrayBuffer.foreach(ArrayBuffer.scala:47) at kafka.common.ZkNodeChangeNotificationListener.purgeObsoleteNotifications(ZkNodeChangeNotificationListener.scala:112) at kafka.common.ZkNodeChangeNotificationListener.kafka$common$ZkNodeChangeNotificationListener$$processNotifications(ZkNodeChangeNotificationListener.scala:97) at kafka.common.ZkNodeChangeNotificationListener.processAllNotifications(ZkNodeChangeNotificationListener.scala:77) at kafka.common.ZkNodeChangeNotificationListener.init(ZkNodeChangeNotificationListener.scala:65) at kafka.security.auth.SimpleAclAuthorizer.configure(SimpleAclAuthorizer.scala:136) at kafka.admin.AclCommand$.withAuthorizer(AclCommand.scala:73) at kafka.admin.AclCommand$.addAcl(AclCommand.scala:80) at kafka.admin.AclCommand$.main(AclCommand.scala:48) at kafka.admin.AclCommand.main(AclCommand.scala) Caused by: org.apache.zookeeper.KeeperException$NoAuthException: KeeperErrorCode = NoAuth for /kafka-acl-changes/acl_changes_0000000002 at org.apache.zookeeper.KeeperException.create(KeeperException.java:117) at org.apache.zookeeper.KeeperException.create(KeeperException.java:51) at org.apache.zookeeper.ZooKeeper.delete(ZooKeeper.java:1416) at org.I0Itec.zkclient.ZkConnection.delete(ZkConnection.java:104) at org.I0Itec.zkclient.ZkClient$11.call(ZkClient.java:1042) at org.I0Itec.zkclient.ZkClient.retryUntilConnected(ZkClient.java:985)
Possible Causes
The user does not belong to the kafkaadmin group. Kafka provides a secure access interface. Only users in the kafkaadmin group can perform the setting operation.
Cause Analysis
- After the client command is run, the "NoAuthException" exception is reported.
 - Run the client command klist to query the current authenticated user.
[root@10-10-144-2 client]# klist Ticket cache: FILE:/tmp/krb5cc_0 Default principal: test@HADOOP.COM Valid starting Expires Service principal 01/25/17 11:06:48 01/26/17 11:06:45 krbtgt/HADOOP.COM@HADOOP.COM
The test user is used in this example.
 - Run the id command to query the user group information.
[root@10-10-144-2 client]# id test uid=20032(test) gid=10001(hadoop) groups=10001(hadoop),9998(ficommon),10003(kafka)
Solution
MRS Manager:
- Log in to MRS Manager.
 - Choose System > Manage User.
 - In the Operation column of the user, click Modify.
 - Add the user to the kafkaadmin group.
[root@host1 client]# id test uid=20032(test) gid=10001(hadoop) groups=10001(hadoop),9998(ficommon),10002(kafkaadmin),10003(kafka)
FusionInsight Manager:
 - Choose System > Permission > User.
 - Locate the row that contains the target user, and click Modify.
 - Add the user to the kafkaadmin group. Click OK.
[root@10-10-144-2 client]# id test uid=20032(test) gid=10001(hadoop) groups=10001(hadoop),9998(ficommon),10002(kafkaadmin),10003(kafka)
