Error "AdminOperationException" Is Displayed When a Kafka Topic Is Deleted
Symptom
When running the following command on the Kafka client to set the ACL for a topic, it is found that the ACL cannot be set.
kafka-topics.sh --delete --topic test4 --zookeeper 10.5.144.2:2181/kafka
The error message "ERROR kafka.admin.AdminOperationException: Error while deleting topic test4" is displayed.
Details are as follows:
Error while executing topic command : Error while deleting topic test4 [2017-01-25 14:00:20,750] ERROR kafka.admin.AdminOperationException: Error while deleting topic test4 at kafka.admin.TopicCommand$$anonfun$deleteTopic$1.apply(TopicCommand.scala:177) at kafka.admin.TopicCommand$$anonfun$deleteTopic$1.apply(TopicCommand.scala:162) at scala.collection.mutable.ResizableArray$class.foreach(ResizableArray.scala:59) at scala.collection.mutable.ArrayBuffer.foreach(ArrayBuffer.scala:47) at kafka.admin.TopicCommand$.deleteTopic(TopicCommand.scala:162) at kafka.admin.TopicCommand$.main(TopicCommand.scala:68) at kafka.admin.TopicCommand.main(TopicCommand.scala) (kafka.admin.TopicCommand$)
Possible Causes
The user does not belong to the kafkaadmin group. Kafka provides a secure access interface. Only users in the kafkaadmin group can delete topics.
Cause Analysis
- After the client command is run, the "AdminOperationException" exception is reported.
 - Run the client command klist to query the current authenticated user.
[root@10-10-144-2 client]# klist Ticket cache: FILE:/tmp/krb5cc_0 Default principal: test@HADOOP.COM Valid starting Expires Service principal 01/25/17 11:06:48 01/26/17 11:06:45 krbtgt/HADOOP.COM@HADOOP.COM
The test user is used in this example.
 - Run the id command to query the user group information.
[root@10-10-144-2 client]# id test uid=20032(test) gid=10001(hadoop) groups=10001(hadoop),9998(ficommon),10003(kafka)
Solution
MRS Manager:
- Log in to MRS Manager.
 - Choose System > Manage User.
 - In the Operation column of the user, click Modify.
 - Add the user to the kafkaadmin group. Click OK.
[root@10-10-144-2 client]# id test uid=20032(test) gid=10001(hadoop) groups=10001(hadoop),9998(ficommon),10002(kafkaadmin),10003(kafka)
FusionInsight Manager:
 - Choose System > Permission > User.
 - Locate the row that contains the target user, and click Modify.
