Help Center/
      MapReduce Service/
        User Guide (ME-Abu Dhabi Region)/
        Troubleshooting/
        Using HDFS/
      Common File Read/Write Faults
Symptom
When a user performs a write operation on HDFS, the message "Failed to place enough replicas:expected…" is displayed.
Cause Analysis
- The data receiver of the DataNode is unavailable.
The DataNode log is as follows:
2016-03-17 18:51:44,721 | WARN | org.apache.hadoop.hdfs.server.datanode.DataXceiverServer@5386659f | hadoopc1h2:25009:DataXceiverServer: | DataXceiverServer.java:158 java.io.IOException: Xceiver count 4097 exceeds the limit of concurrent xcievers: 4096 at org.apache.hadoop.hdfs.server.datanode.DataXceiverServer.run(DataXceiverServer.java:140) at java.lang.Thread.run(Thread.java:745)
 - The disk space configured for the DataNode is insufficient.
 - DataNode heartbeats are delayed.
Solution
- If the DataNode data receiver is unavailable, add the value of the HDFS parameter dfs.datanode.max.transfer.threads on Manager.
 - If disk space or CPU resources are insufficient, add DataNodes or ensure that disk space and CPU resources are available.
 - If the network is faulty, ensure that the network is available.
   Parent topic: Using HDFS
