On this page
Failed to Start Flume
Updated on 2022-12-08 GMT+08:00
Symptom
The Flume service fails to be installed or restarted.
Cause Analysis
  1. The heap memory of Flume is greater than the remaining memory of the server. The Flume startup log shows the following information:
    [CST 2019-02-26 13:31:43][INFO] [[checkMemoryValidity:124]] [GC_OPTS is invalid: Xmx(40960000MB) is bigger than the free memory(56118MB) in system.] [9928]
  2. The permission on the Flume file or folder is abnormal. The following information is displayed on the GUI or in the background:
    [2019-02-26 13:38:02]RoleInstance prepare to start failure [{ScriptExecutionResult=ScriptExecutionResult [exitCode=126, output=, errMsg=sh: line 1: /opt/Bigdata/MRS_XXX/install/FusionInsight-Flume-1.9.0/flume/bin/flume-manage.sh: Permission denied
  3. The JAVA_HOME is incorrectly configured. The Flume agent startup log shows the following information:
    Info: Sourcing environment configuration script /opt/FlumeClient/fusioninsight-flume-1.9.0/conf/flume-env.sh
    + '[' -n '' ']'
    + exec /tmp/MRS-Client/MRS_Flume_ClientConfig/JDK/jdk-8u18/bin/java '-XX:OnOutOfMemoryError=bash /opt/FlumeClient/fusioninsight-flume-1.9.0/bin/out_memory_error.sh /opt/FlumeClient/fusioninsight-flume-1.9.0/conf %p' -Xms2G -Xmx4G -XX:CMSFullGCsBeforeCompaction=1 -XX:+UseConcMarkSweepGC -XX:+CMSParallelRemarkEnabled -XX:+UseCMSCompactAtFullCollection -Dkerberos.domain.name=hadoop.hadoop.com -verbose:gc -XX:+UseGCLogFileRotation -XX:NumberOfGCLogFiles=10 -XX:GCLogFileSize=1M -XX:+PrintGCDetails -XX:+PrintGCDateStamps -Xloggc:/var/log/Bigdata//flume-client-1/flume/flume-root-20190226134231-%p-gc.log -Dproc_org.apache.flume.node.Application -Dproc_name=client -Dproc_conf_file=/opt/FlumeClient/fusioninsight-flume-1.9.0/conf/properties.properties -Djava.security.krb5.conf=/opt/FlumeClient/fusioninsight-flume-1.9.0/conf//krb5.conf -Djava.security.auth.login.config=/opt/FlumeClient/fusioninsight-flume-1.9.0/conf//jaas.conf -Dzookeeper.server.principal=zookeeper/hadoop.hadoop.com -Dzookeeper.request.timeout=120000 -Dflume.instance.id=884174180 -Dflume.agent.name=clientName1 -Dflume.role=client -Dlog4j.configuration.watch=true -Dlog4j.configuration=log4j.properties -Dflume_log_dir=/var/log/Bigdata//flume-client-1/flume/ -Dflume.service.id=flume-client-1 -Dbeetle.application.home.path=/opt/FlumeClient/fusioninsight-flume-1.9.0/conf/service -Dflume.called.from.service -Dflume.conf.dir=/opt/FlumeClient/fusioninsight-flume-1.9.0/conf -Dflume.metric.conf.dir=/opt/FlumeClient/fusioninsight-flume-1.9.0/conf -Dflume.script.home=/opt/FlumeClient/fusioninsight-flume-1.9.0/bin -cp '/opt/FlumeClient/fusioninsight-flume-1.9.0/conf:/opt/FlumeClient/fusioninsight-flume-1.9.0/lib/*:/opt/FlumeClient/fusioninsight-flume-1.9.0/conf/service/' -Djava.library.path=/opt/FlumeClient/fusioninsight-flume-1.9.0/plugins.d/native/native org.apache.flume.node.Application --conf-file /opt/FlumeClient/fusioninsight-flume-1.9.0/conf/properties.properties --name client
    /opt/FlumeClient/fusioninsight-flume-1.9.0/bin/flume-ng: line 233: /tmp/FusionInsight-Client/Flume/FusionInsight_Flume_ClientConfig/JDK/jdk-8u18/bin/java: No such file or directory
Solution
  1. Increase the size of the heap memory (xmx).
  2. Compare the file and folder permissions with those for node where Flume is started properly and change the incorrect file or folder permissions.
  3. Reconfigure JAVA_HOME. On the client, replace the value of JAVA_HOME in the ${install_home}/fusioninsight-flume-Flume version/conf/ENV_VARS file. On the server, replace the value of JAVA_HOME in the ENV_VARS file in the etc directory.
    To obtain the value of JAVA_HOME, log in to the node where Flume is properly started and run the echo ${JAVA_HOME} command.
    ${install_home} is the installation path of the Flume client.
