Help Center/
      MapReduce Service/
        User Guide (ME-Abu Dhabi Region)/
        Troubleshooting/
        Cluster Management/
      MRS Becomes Abnormal After hostname Modification
Issue
What should I do if MRS becomes abnormal after hostname is modified?
Symptom
MRS becomes abnormal after hostname is modified.
Possible Cause
The hostname modification causes compatibility problems and faults.
- Log in to any node in the cluster as user root.
 - Run the cat /etc/hosts command on the node to check the value of hostname of each node and set the newhostname variable based on the value.
 - Run the sudo hostnamectl set-hostname ${newhostname} command on the node where hostname is modified to restore the correct hostname.
     ${newhostname}: new value of hostname
 - After the modification, log in to the node where hostname is modified, and check whether the new hostname takes effect.
   Parent topic: Cluster Management
