Using a Kudu Client
Kudu is a columnar storage manager developed for the Apache Hadoop platform. Kudu shares the common technical properties of Hadoop ecosystem applications. It is horizontally scalable and supports highly available operations.
The cluster client has been installed. For example, the client is installed in the /opt/hadoopclient directory. The client directory in the following operations is only an example. Change it to the actual installation directory.
- Log in to the node where the client is installed as the client installation user.
 - Run the following command to go to the client installation directory:
cd /opt/hadoopclient
 - Run the following command to configure environment variables:
source bigdata_env
 - Run the Kudu command line tool.
Run the command line tool of the Kudu component to view help information.
kudu -h
The command output is as follows:
Usage: ./kudu <command> [<args>] <command> can be one of the following: cluster Operate on a Kudu cluster diagnose Diagnostic tools for Kudu servers and clusters fs Operate on a local Kudu filesystem hms Operate on remote Hive Metastores local_replica Operate on local tablet replicas via the local filesystem master Operate on a Kudu Master pbc Operate on PBC (protobuf container) files perf Measure the performance of a Kudu cluster remote_replica Operate on remote tablet replicas on a Kudu Tablet Server table Operate on Kudu tables tablet Operate on remote Kudu tablets test Various test actions tserver Operate on a Kudu Tablet Server wal Operate on WAL (write-ahead log) files
     The Kudu command line tool does not support DDL and DML operations, but provides the refined query function for the cluster, master, tserver, fs, and table parameters.
Common operations:
- Check the tables in the current cluster.
./kudu table list KuduMaster instance IP1:7051, KuduMaster instance IP2:7051, KuduMaster instance IP3:7051
 - Query the configurations of the KuduMaster instance of the Kudu service.
 - Query the schema of a table.
./kudu table describe KuduMaster instance IP1:7051, KuduMaster instance IP2:7051, KuduMaster instance IP3:7051 table name
 - Delete a table.
./kudu table delete KuduMaster instance IP1:7051, KuduMaster instance IP2:7051, KuduMaster instance IP3:7051 table name
       To obtain the IP address of the KuduMaster instance, choose Components > Kudu > Instances on the cluster details page.
