Using a Kafka Client
You can create, query, and delete topics on a cluster client.
The client has been installed. For example, the client is installed in the /opt/hadoopclient directory. The client directory in the following operations is only an example. Change it to the actual installation directory.
Using the Kafka Client (Versions Earlier Than MRS 3.x)
- View the IP addresses of the ZooKeeper role instance.
Record any IP address of the ZooKeeper instance.
 - Log in to the node where the client is installed.
 - Run the following command to switch to the client directory, for example, /opt/hadoopclient/Kafka/kafka/bin.
cd /opt/hadoopclient/Kafka/kafka/bin
 - Run the following command to configure environment variables:
source /opt/hadoopclient/bigdata_env
 - If Kerberos authentication is enabled for the current cluster, run the following command to authenticate the user. If Kerberos authentication is disabled, skip this step.
kinit Kafka user
 - Create a topic.
sh kafka-topics.sh --create --topic Topic name --partitions Number of partitions occupied by the topic --replication-factor Number of replicas of the topic --zookeeper IP address of the node where the ZooKeeper instance resides:clientPort/kafka
 - Run the following command to view the topic information in the cluster:
sh kafka-topics.sh --list --zookeeper IP address of the node where the ZooKeeper instance resides:clientPort/kafka
 - Delete the topic created in 6.
sh kafka-topics.sh --delete --topic Topic name --zookeeper IP address of the node where the ZooKeeper instance resides:clientPort/kafka
Type y and press Enter.
Using the Kafka Client (MRS 3.x or Later)
kinit Kafka user
 - Create a topic.
